Drivers side window controls not working!!!
Old Jul 17, 2010 | 10:31 AM
lmob1600's Avatar
Hey fellas...2000 f150 4x4. Window control on the drivers side will not work either driverside or pass side. But i can operated the pas side window from the pass side. I checked the fuses...all good. I just bought a new switch...that was not it either. Do you guys think i have a short?
Old Jul 17, 2010 | 11:01 AM
SSCULLY's Avatar
Pull the switch panel, and check the driver's side switch for power on the Light Blue w/ Black stripe wire with the key in the accessory or run position.
If the switch does not work, chances are it is an open not a short
Old Jul 17, 2010 | 01:10 PM
lmob1600's Avatar
What do you mean by an open? Sorry just not a pro.
Old Jul 17, 2010 | 02:01 PM
lmob1600's Avatar
ok..i have power to the blue wire...but switch will still not work?
Old Jul 17, 2010 | 03:20 PM
jgger's Avatar
"Open" as in broken wire or a connection has come loose.
Short is where the power is grounding out.
Old Jul 17, 2010 | 07:31 PM
SSCULLY's Avatar
You need to check the Light Blue w/ Black stripe wire, not a blue wire.
Old Jul 17, 2010 | 08:47 PM
lmob1600's Avatar
thanks fellas...bought the truck used un seen...wiring in the switch was wrong. Someone messed with it. It also needed a new switch! Thanks for your help!
