No Power at Power Point
Old Mar 16, 2001 | 10:32 PM
model a's Avatar
Post No Power at Power Point
Wiring diagram doesn't show an in-line fuse for the power point also known as auxillary power socket but the fuse in the fuse box is good and there is no power. Cigarette lighter works. I remember a post saying there was an in-line fuse but haven't located it. Anyone else had this problem? '98 F-250 LD XLT SuperCab.
Old Mar 18, 2001 | 12:27 AM
hmustang's Avatar
Post
On my truck a 2000 the fuse to the power point is in the fuse box under the hood on the left (drivers) side of the truck and
the fuse for the lighter is under the das both 20 amp fuses.
2000 F150 XLT Reg. cab
4.6 Triton Engine
4x2 3.55 rear end gear
sliding rear window
automatic keyless entry
white styleside short box
Old Mar 19, 2001 | 02:48 PM
model a's Avatar
Post
I just checked the fuses to the power point and lighter again and they are good. Checked them with a meter this time, as I have been fooled by fuses that looked "good" but were bad. I hate to start ripping out wiring but I need the extra power source.
98 F-250 LD SC 5.4 3.73 Rhino Liner ARE Cap
PIAA's Black Westin Bars Tekonsha Sentinel Brake Controller
Travel Trailer Totin' Son of a gun.
Ford is my middle name.
Old Mar 19, 2001 | 07:19 PM
Chucky Tucky's Avatar
Post
Relays, Relays, Relays, to many in my Screw. Your power point may be controlled by one. The fuse protects the wiring up to the relay. The relay conducts the current.
A possibility.
2001 Screw, 4x4, 5.4L, 3.55LS, trailer tow III, 255-16 tires, skids.
Superchip
Gibson Stainless SS
AirRaid FIPK
Century Cap
Line X, other misc.
