Wiper Switch
Old Mar 7, 2001 | 10:19 PM
Reamer's Avatar
Post Wiper Switch
Has Ford issued a recall on the wiper switch?
I had a '99 Ranger P.O.S. where the wiper switch would not spray fluid when you push in the tip, and would activate the wipers on it's own. My '97 F-150 is doing the same thing!
Old Mar 8, 2001 | 07:36 PM
Flatlander's Avatar
Lightbulb
Check out the link below, maybe it will help you. My washer has worked fine since doing this procedure, but sometimes my delay varies. Works a whole lot better than it used to! I'm pretty sure there's no recall, but maybe a TSB. I was out of warranty so didn't really check into it.
https://www.f150online.com/f150board...ML/000210.html
'97 F-150 Lariat SuperCab 4X4
  • White/Silver, 4.6L, Auto.,Open 3:55
  • Tinted Windows/Bedmat/Toolbox/Lund Bug Deflector/Ventvisors/Extra Horns
  • 265/75/16 BFGoodrich AT's on polished 16x8 AR-136's
  • Cat-back Dual Exhaust (Straight pipes with big chrome tips)
  • Black Polar Bear Grille Guard
  • Monkey'd around with the Torsion Bars
Old Mar 9, 2001 | 02:43 PM
Reamer's Avatar
Talking
Thanks Flatlander
Gonna try it this weekend!
Reamer
Old Mar 9, 2001 | 02:52 PM
Flatlander's Avatar
Smile
No problem, hope it works for ya. Just watch that the little pieces don't fly everywhere. It comes apart really easy. Good Luck to ya!
Old Mar 9, 2001 | 02:54 PM
popeye's Avatar
Post
My 97 has problems too. Its really bad when the weather gets cold. Is there a recall?
Old Jan 23, 2002 | 09:29 AM
mcmjoe's Avatar
Looking for help for wiper fluid switch
Flatlander, I am having problems with my 97 F150's wiper fluid switch. Couldnt find the link you provided. Can you point me in the right direction? Thanks.
Old Jan 24, 2002 | 01:09 AM
Wino's Avatar
i have seen a guy take the tip apart and clean the contact's in the sw. i have not done this. but his has been working fine for a long time now. there is a cover that run's up the back of the sw. arm. and the tip of the cover pop's off if a remember right. and there is a screw behind there. to acces. those contact's. they get dirty very easy. and that's what cause's most concern's. i would ask him again to make sure. but will not see him until next week. good luck.
Old Jan 24, 2002 | 08:33 AM
mcmjoe's Avatar
Thanks Wino, I will try it. Keep me posted if you talk to your buddy.
