spedometer
Old Jan 31, 2001 | 09:41 PM
Adam Frick's Avatar
Angry spedometer
I have a 1991 f150 with a 351 and push button overdrive. when its cold out my spedometer just about bottoms out. as it warms up it starts reading accuratly. what schould i do?
Old Jan 31, 2001 | 10:39 PM
Nomopar4me's Avatar
Post
if you can find it (kind of a dinosaur) there is speedo head lube. It is old and probably REAL hard to find. However, it sounds like the head is junk. SOrry to be the bearer of bad news.
Old Jan 31, 2001 | 10:45 PM
Adam Frick's Avatar
Post
how do I fix this? how much would it codt and how hard of a job is it???
Old Feb 9, 2001 | 07:12 AM
kidtriton's Avatar
Post
no lube will fix this, its all electronic, i have to replace clusters for that prob, and the tachs do the same thing too.
Old Feb 9, 2001 | 09:48 PM
Nomopar4me's Avatar
Post
91's are NOT electronic. The odometer doesn't have a digital display does it? If it does, it is a 92 not a 91. This was the last year of this body style. The 92 trucks were the first with electronic speedos and digital odometers. Lube is gona be HARD to find. It is not hard to do.. takes maybe two hours at the most. probably bet on around a hundred and a half if you take it to someone to do, that's just for labor. The best bet is to contact your dealer snd see if he can get a head for it. if he can, I assume it will be around a hundred and a quarter. They are seperate units and do not have to be replaced in the cluster. So to have it done, figure an easy $275. IF the dealer can't get one you should be able to find one in the boneyards for cheaper and MAY be able to get the complete cluster for just a little money.
[This message has been edited by Nomopar4me (edited 02-09-2001).]
Old Feb 10, 2001 | 01:37 AM
kidtriton's Avatar
Post
oooopppsss!!!! what was i thinking. Actually i was thinking of 97 and up trucks because thats what this site is mostly about. I didnt even realize he said 91 model. sorry
Old Feb 10, 2001 | 10:12 PM
Nomopar4me's Avatar
Post
I tried to help a guy once that said he had an 88. It was actually a 98. He thought I was smokin when I told him the wrong thing!
