Frustrated in Ga
Old Feb 6, 2001 | 09:10 PM
FORDTOUGH44's Avatar
Angry Frustrated in Ga
Hi.....I am posting this for a friend. She has a 2000 XLT Ext. Cab Flareside, power everything. She, in the past month has been having electrical problems. First, her windshield wipers stopped working, and of course it happened on a rainy day (poor her!). Second, her radio will sometimes work then sometimes will not. Ok now, she has problems with the truck starting. She has to keep turning it off, then on, etc and then when she does finally get it started the radio sometimes will not work.
She took it to the dealership and they changed out the wiper motor. Said they couldn't find anything else wrong. So of course when she got it back home, it wouldn't start again. She is getting ready to take it back to Ford again.
I was just wondering if anyone else has had this same problem and could offer any suggestions??
Thanks!
Old Feb 6, 2001 | 09:35 PM
GIJoeCam's Avatar
Post
I'v egot a couple of thoughts... but I need more info first... what does it do, exactly? The wiper motor could have been bad... if that doesn't fix it, it could be the switch or the control module.
On the electrical front, what, exactly does it do?? When she turns the key and it doesn't start, is there power at the starter or not? Trace the wires back to the solenoid and battery... the one on the firewall isn't the one she's looking at either... that's the accessory solenoid. There's another one on the side of the starter... could be that the wire on the solenois is loose or not getting juice intermittently... could be a loose connection, bad switch, or bad engine ground... a test light should narrow it down... also, when it doesn't start, turn the key to the start position, and wiggle it, bang on the column, etc... if that helps, it might be the switch. If not, move on with a test light and see....
Let us know what happens.
Any other thoughts, guys?
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof, built 11/99 picked up 10/00!Clear Corners, Manik Stainless Steel 1-piece brush guard, Custom CB wiring, Uniden PC76-XLW CB radio with K-40 Magna-Mount antenna (for now), 1 set of 165 watt KC Daylighters (for now... more on the way) Custom switch mounting plate and overhead console, Bully Stainless Steel Trailer hitch drawbarw/ 2" stainless steel ball.
List of planned mods: Clear tails, torsion bar tweak, bug deflector, spray in liner, and a tonneau of some sort...
93 Probe GT teal, OE rims painted to match, bone stock drivetrain.
Old Feb 7, 2001 | 07:15 PM
gofish's Avatar
Post
From other threads I recall some component called a GEM that could be the problem. Also, if the wipers are still intermittent, I'd use Rain-X as a temporary measure that would allow me to drive in a downpour without wipers.
Old Feb 8, 2001 | 08:01 PM
GIJoeCam's Avatar
Post
Oh, yeah, forgot about that... there was a TSB (technical service bulletin) for the GEM module... the little control box that controls all the accessories. That could be it... The TSB number is available on the NHTSA web site. Numerous people had this problem.
-Joe-
Old Feb 10, 2001 | 01:58 PM
sigmanu1524's Avatar
Post
I am having the same problems with my truck I took it in yesterday and had the starter motor replaced but now the windows and the dome light do not work. So i am taking it back again
