Tachometer connection
Old Nov 19, 2000 | 09:09 PM
Powertrax's Avatar
Question Tachometer connection
Was interested in putting in an aftermarket tachometer, but I can't find the pick up for the tach siginal. Was wondering if anyone has an aftermarket tach and if so how did you hook it up, or if not do you have any suggestions on how to go about hooking a tachometer up.
98 F-150XL, blk/slv, 4.2 5speed, 4X2, Tonneau cover, class III hitch, Powertrax Locker
snapf150@hotmail.com
Old Nov 19, 2000 | 09:31 PM
JDm's Avatar
JDm
Post
Powertrax,
Sorry if im off topic but what do you think of your locker? and how much did it cost and how much was the install.
thanks,
JDm
Old Nov 19, 2000 | 09:51 PM
Powertrax's Avatar
Thumbs up
JDm,
It's great, can't believe how well it works. I think it was well worth the money, limited slips and posi units use clutches which will burn out after awhile and only give you approximatly 20% torque transfer to the other wheel when they are brand new, the only benefit I see of the limited slips are that they are much smoother on the steets. But if you want maximum traction, I suggest you get a locker. It was about $400 after shipping and handling. The installation was really easy, it took me about 2 to 3 hours in my driveway, that's it. no special tools needed.
Old Nov 20, 2000 | 11:27 AM
JDm's Avatar
JDm
Talking
Powertrax,
thanks for the info!! I just called national tire & wheel and they have one for my truck at $374.95 and free shipping( that looks pretty good right )
thanks again,
JDm
[This message has been edited by JDm (edited 11-20-2000).]
Old Nov 20, 2000 | 05:34 PM
fourhour's Avatar
Post
Powertrax, I needed the Tach wire to install an aftermarket remote start. The instructions indicated the tach wire as: For the 4.6 Triton, tach is PINK/WHITE at driver side coil, on 5.4 Triton it's PINK/WHITE at harness through firewall on drivers side. (that's where I found mine, on the top of three thick harness's and it was'nt easy to connect to) For the V10, use the negative side of any ot the 10 injectors on the top of the engine.
Good luck, I don't know what they mean by the drivers side coil. Dennis
'98 White Lariat
fourhour@yahoo.com
Old Nov 29, 2000 | 03:06 PM
BigDaddyXL's Avatar
Post
Powertrax, so have you hooked up the tach, is so how did you go about doing it. I just got a pillar holder like on the lightnings, and was thiking of adding a tach, on my xl also.
