Daytime Running Lights
Old Sep 26, 2000 | 07:45 PM
mas-cerveza's Avatar
Lightbulb Daytime Running Lights
I bought a 99 F150 XLT here in Alaska, and it came from canada. I tried to disable the drl's by pulling the fuse at the main box in the engine compartment, but of course the fog lights are wired with them. I've thought about cutting the wire that goes to the fusebox, but there is a cluster of about 40 wires. Any suggestions? ( I really dislike the daytime running lights )
Thanks in advance, Mike
Old Sep 27, 2000 | 09:16 PM
FedExPilot's Avatar
Cool
Mike;
Try these links. Some of us would like to be in your position - - having DRL. I believe you'll find an easy, "non-intrusive" solution after reverse engineering members' info on (possible) installation http://www.voicenet.com/~storm/drl/ https://www.f150online.com/f150board...ML/000088.html https://www.f150online.com/f150board...ML/000009.html
BTW; some insurance companies will give you a discount for the DRL. Good luck ....
Fog Lights with parking lights .... how does he do it ?
https://www.f150online.com/f150board...ML/000552.html
<A HREF="http://albums.photopoint.com/j/View?u=1023393&a=8790857&p=28542295&Sequence=1" TARGET=_blank> </A> <A HREF="http://albums.photopoint.com/j/View?u=1023393&a=8790857&p=28542675&Sequence=2" TARGET=_blank> </A>
2001 F-150 Super Crew Lariat 4x4
5.4 engine; Chestnut w/ gold trim; Captain's Chairs; Ford/ Duraliner bed insert; Six disc CD changer (in center console); Fosgate FNP1614 component speakers (front); Pioneer TS-A6855 speakers (rear); 8 inch MTX sub in custom built, center console, sealed enclosure; ZAPCO AG150 amplifier; Moon roof; 98/99 Expedition center console; Bed extender; Class 3 trailer hitch
[This message has been edited by FedExPilot (edited 09-27-2000).]
Old Sep 29, 2000 | 08:24 PM
Thumbs up
Thank you very much
Old Oct 17, 2000 | 01:52 PM
JDF's Avatar
JDF
Unhappy
I just picked up my 2001 built in Canada.
I also picked up the F150 accesories catalog that states the DRL is standard equipment on vehicles built in Canada but mine don't turn on. I do have fog lights that work so it's not just a missing fuse.
What's up with that? I would like to have them.
2001 F150 SC SPORT 4X4 FLARESIDE
* Black
* 4.6 240 H.P.
* awesome factory 10 spoke wheels
* "MAN"ual shift 4x4
* 3.55 Limited slip
* Captains chairs W/console
* Factory tube steps
* Slider
Old Oct 18, 2000 | 10:53 AM
RBurton's Avatar
Angry
I too have a 98 built in Canada. Not only did in not come with DRL, but the wiring harness doesn't have the connector to plug a DRL module into. After many months of questioning and looking around, I just gave up.
Old Oct 18, 2000 | 06:09 PM
F150Sven's Avatar
Lightbulb
Try pulling the DRL relay in the main fuse box under the hood. Your owner's manual has a diagram showing which one is which.
Old Oct 19, 2000 | 06:40 PM
JDF's Avatar
JDF
Exclamation
OK, to turn them on, you need a relay block to replace the loop back plug, and a resistor to plug in where there is currently a cap.
Anybody have these part #'s yet?
I have located easily where both go
