how do you get to the instrument panel lights
Old Oct 17, 2000 | 02:45 PM
shooter's Avatar
Question how do you get to the instrument panel lights
i just blew the light that illuminates the oil pressure and voltage guages. and cant figure out how to get to them. ive tried but it seems like im going to break something.
thanks for the help!!
$98 black 4.2l 4x4
$superchip
$50 series dual outlet
$profile bug guard
airbox mod(costs nothing)
Old Oct 17, 2000 | 09:21 PM
nitro94's Avatar
Post
From Ford factory manual. Disconnect neg. battery. Remove headlight switch. Use thin tool to help pull it straight out, un hook wires. Release four clips and remove steering column opening cover. Remove instrument panel finish panel. Picture shows 7 bolts. Remove cluster. Picture shows 4 bolts. If equipped remove trans. range indicator.
2000 XLT Bright red, Flareside,extended cab,sport,5.4,bedrug,Extang tonneau.
