Where to tie into electrical system?
Old Oct 10, 2000 | 07:01 PM
Larry@'s Avatar
Question Where to tie into electrical system?
I wanted to install some daytime running lights. I want to hook them up so that the parking lights arent on while the DRL are on and so I dont have to come through the firewall and use the headlight switch. Is there any place that I can tie into so that when I start the truck they come on? I dont care about a switch. I was wondering if anyone knew of a place to tie into in the engine compartment that only gets power when the engine is running and wouldnt cause a voltage drop and have negative effects if tied into. I think you can tie into the altenator but I think this would give continous power even when engine is off? Does anyone have any ideas or know of a wiring diagram? Im sure I could come into the fuse box and get power there but it seems like it would be a hassle coming thru the firewall unless someone knows of an easy spot. If I had to do this could I tie into the radio since it is only on when the key is turned (I have a aftermarket cd player which may already draw alot of power). Thanks for any help!
Old Oct 10, 2000 | 11:28 PM
OhioCrew's Avatar
Lightbulb
Hopefully, Firezap will see this. He is pretty good about mods !!!!!
http://albums.photopoint.com/j/Album...8832&a=8647410
2001 SuperCrew Lariat 4X4
Chestnut/Gold Trim
5.4 Engine
3.55 Limited Slip Axle
Cargo Bed Extender
Leather Captain Chairs
Class III Towing Group
6-Disc C.D. Changer
Mods:
Rhino Lining
A.R.E. LSII Hard Tonneau Cover
Owens Classic Boards
Old Oct 11, 2000 | 07:56 PM
F150Sven's Avatar
Lightbulb
In the main fuse panel in the engine compartment, there is a fuse for DRL/Foglights. I'm guessing this is a hot when ignition is on wire. Use a test light to make sure. Assuming this is the case, you could tie into it downstream of the fuse to run your DRLs. Are these light going to be on all of the time, or do you want them off when the headlights are on. If it's the latter, you will need a relay to break the circuit to the DRLs when the headlights are on.
BTW, if it's just a cd reciever, don't be worried about power drain. Most are not much more powerful than the factory units, just cleaner sounding because the internal amps are better. High powered external amps are what use the juice.
2000 F150 XLT 4X4 Off Road 5.4L Reg. Cab 3.55
Performance Enhancemets:
K&N, WMS Velocity Tube, and Gibson Sweptside...
Audio Enhancements:
All of the above, plus
Sony C7000X HU, Cerwin-Vega SS2502 components(Front), and Blaupunkt PCst573s(Rear)
(For now)
[This message has been edited by F150Sven (edited 10-11-2000).]
Old Oct 11, 2000 | 08:40 PM
redlariet's Avatar
Post
If you want through the firewall, there is a big grommet with a little cable beside the brake booster toward the center of the truck. I wouldn't use the radio for control because it's also on in accessory key position. You may look into the ignition or fuel pump circuits in the fuse box under the hood.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-K&N-3"
pvc air box mod-Granetelli MAF
