Windshield Washer OTS
Old Aug 31, 2000 | 06:30 PM
Kenster's Avatar
Post Windshield Washer OTS
My windshield washer used to work occasionally but now does not pump at all. Is this an easy, cheap fix to replace the pump ( I guess) or should I take it to the shop and pay the $50 deductible?
Old Aug 31, 2000 | 07:51 PM
Rob S's Avatar
Post
Mine does the same thing? push the washer switch and sometimes pumps sometimes doesn't?
I'm pretty sure mine is the switch, if I fiddle with it and turn it just a little while pushing it will work. It is something you can change yourself but not sure of the price of switch or how to make %100 sure that is it.
97 F150 4x4 SC 8' box, 5.4l auto 3.55LS.
Old Sep 1, 2000 | 09:25 AM
Flatlander's Avatar
Post
Mine's like that too. If you move it around a little it works. My intermittent wipers also have a mind of their own. I'd like to figure this out but haven't figured out how to get the switch/lever off without breaking something.
'97 F-150 Lariat Ext. Cab 4X4
  • White/Silver
  • 4.6L, Auto.
  • Tinted Windows/Bedmat/Toolbox/Lund Bug Deflector
  • 265/75/16 BFGoodrich on polished 16x8 AR-136's
  • Cat-back Dual Exhaust
  • Polar Bear Grille Guard
Old Sep 1, 2000 | 04:18 PM
Dennis's Avatar
Post
All the problems you guys are describing are probably from the multi-function switch (turn signal stalk).
As for the washer problem? I'd do a bit of diagnostics. It could possibly be a faulty pump, but I doubt it. The easiest way to tell is to hot wire the pump to the battery to see if it runs or not. Chances are, it's the switch.
Old Sep 1, 2000 | 09:23 PM
Kenster's Avatar
Post
Actually, I am now convinced it is the multi-switch rather than the pump, in which case, I think I am better off taking it into the shop and paying the $50 deductable.
Old Sep 2, 2000 | 04:58 PM
Kenster's Avatar
Post
Unbelievably, I was headed to the dealer this morning to have the switch replaced. On the way I jiggled the switch, as you guys suggested, while pushing the wash button. It started working for the first time in several months. I decided to save my money and wait until it really goes out. Thanks for your help.
Old Sep 4, 2000 | 09:54 PM
GIJoeCam's Avatar
Post
Sounds like you've all got the ghost wipers. There was a TSB for the 97 & 98s, and I believe there was a recall for the 99's and 00's just for that purpose. Replacement parts should be available for the DIY-er, I would think Call the service department for more info (it might take some calling around before you find a service-writer that is willing to give out that info over the phone, though)
-Joe-
Old Oct 2, 2000 | 09:59 AM
BlueFlareside's Avatar
Post
Do you have the TSB for the washer problem? I am taking mine in for the same problem this week. My washers only work if I turn the wipers on low or high and then push the end in.
Thanks,
Steve
Old Oct 2, 2000 | 11:22 PM
summitman's Avatar
Post
Hey guys the TSB # is 00-9-6 I don't remember but I think its for 99-01 only. Give it a try.
98 f150 4.6 auto 4x4 supercab-short box/bright red & black/6 disk cd changer/ dynomax cat back/k&n fipk/super chip/lund taillight covers/clear corner lens/factory fog lamps/pace edwards box cover/ultra wheels/LT265-75-16 BFG/ westin nerf bars/steel horse billit grill & bumper insert/reflex shocks/bosch plat. plus 4/accel wires/auto start/left hand grab handle/skidoo summit 700 high mark/FORD DEALERSHIP
Old Oct 8, 2000 | 06:46 PM
Post
I took mine in last week because the washers would not work unless I turned the wipers on (and that did not even work all of the time). The ended up replcaing the multi-function switch (stalk) that controls the wipers and turn signals and now it works fine.
Steve
'98 F-150 XLT SuperCab Flareside, Auto, 4.6L, 4X2, 3.55 LS, 6-CD changer, Moonlight Blue with tan interior, Captains Chairs
Mods[*]Window tint[*]Extang Classic[*]Platinum Tonno[*]Lund Interceptor bug deflector[*]Wizard Superwhite Bulbs[*]Pendaliner bedliner[*]Expedition center console
My F-150 Page
