Radio won't turn off!
The radio won't turn off when you shut the truck off and take the keys out?
Am I the only one and if not what's going on???
2000 XLT supercab, 4x4 7700lb. package, 5.4L, 3.73 LS,skids,rear sway-bar,CD changer,MagnaCharger, Flowmaster,Superchip, Airaid, Gibson Headers, Island Blue
Interesting...possibly a defect in your ignition switch that does not shut it off when the switch is in the off position...????
Maybe it's Christine back as a truck....
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with super engine cooling/Auxilary transmission cooling HD package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil and filter
[This message has been edited by Dustoff (edited 10-04-2000).]
Christine back as a truck...I couldn't be so lucky!
I found that the heater motor wouldn't shut off either. Also the transfer case switch was cycling and clicking. Gotta be the GEM module.
I know on some of the newer vehicles you can shut the key off and retain the window and stereo function until you open the door... does it lose power when you open the door? Otherwise, you might have a relay under the hood that's sticking in the on position, or a bad ignition switch. Either way, letus know what you find.
-Joe-
98 Explorer (Lemon Law Case in Progress)
Deposit on '00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Sunroof, currently missing the fuel filler door, but they're working on that..
-Joe-
Turns out to be a leak in the windshield somewhere. The water is running into the GEM module and causing the trouble. My dealer is working on it.
