Erratic power window operation
Old Sep 2, 2000 | 03:28 PM
jake565's Avatar
Angry Erratic power window operation
The power windows in my 1999 F-150 are erratic. If the dome light does not come on when you open the door, the windows will not operate. Is there an easy at-home fix or do I have to send it off to the dealer for 2-3 days.
Old Sep 15, 2000 | 08:29 PM
kman's Avatar
Cool
I had a problem with my 97 that caused the windows to quit and the light came on when I had the heater on. After tearing the whole dash out and checking all connectors and wiring I found a loose ground on the passenger side behind the kick panel.
I would check that out first there is also a ground connection on the Driver side kick panel. If this dont fix it let me know I have a lot of diagrams for the electrical connecters and wiring.
97 150 4x4XLT flareside reg cab 4" warn BLACK DIAMOND suspension lift.
Old Sep 18, 2000 | 10:19 AM
gg98's Avatar
Post
I believe your problem is a faulty Delayed Power Relay.
Here are the symptoms:
When you get in the truck in the morning, there is no power to the interior lights and the power windows will not work. Everything else is normal.
After a short time, you hear a click under the lower left dash, and the lights and windows work.
The Delayed Power Relay was stuck. This relay allows the power windows to work after the ignition is turned off. When the door is opened, and the interior lights come on, power to the windows is cut. If this relay gets stuck, the lights and windows get fouled up.
The relay is located in the lower left socket in the fuse block. It is a $6 part.
Old Sep 18, 2000 | 07:03 PM
jake565's Avatar
Thumbs up
Thanks gg98, sounds like just the fix I'm looking for. I made a copy of your reply to give to my dealer since the truck is still under warranty. This should put him on the right track.
Tom J.
Old Sep 22, 2000 | 12:34 AM
dave_f's Avatar
Post
I had the same problem.
There is a service bulletin on it, but my
wife has hidden the receipt where the
info is written down. Post if you need
it and I will try to find it.
99 F-150 5.4L 4WD S/C XLT, 3.55LS and Tow
Pace-Edwards Roll Top Cover
Old Sep 22, 2000 | 04:48 AM
jake565's Avatar
Talking
Dave_f, thanks, if it's not too much trouble would like to have the service bulletin number.
Tom J.
Old Sep 26, 2000 | 06:01 PM
elafrage's Avatar
Cool
I've had the same problems. I have a 98 F150 v6 xlt. In the morning the windows would not work (this happened 2 times) and 1 time my dome light failed to come on. after a couple of minutes, I heard a click of some sort, and the windows started working. I went to 2 dealerships with the same responce from both, "bring it in for diagnostics." Any one else with a solution to the problem?
Old Sep 26, 2000 | 09:32 PM
jake565's Avatar
Talking
To elafrage: look at the post from gg98. Says it all right there.
Tom J.
Old Sep 27, 2000 | 09:27 PM
dave_f's Avatar
Post
On my work up shhet it says
TSB 00-19-02
I can't figure out how to translate the numbers, but
if you look in the TSB area of F150 online
it seems to be the same as
Service Bulletin Number: 0087
Bulletin Sequence Number: 135
Date of Bulletin: 0004
NHTSA Item Number: SB613581
Make: FORD TRUCK
Model: F150
Year: 1999
Component: ELECTRICAL SYSTEM
Summary: CONCERNS WITH COURTESY, GLOVE COMPARTMENT, UNDERHOOD, RUNNING BOARD LAMPS; POWER
WINDOWS; RADIO; AND REAR WIPER ALL INOPERATIVE IN THE MORNING OR AFTER VEHICLE IS LEFT UNATTENDED
FOR 45 MINUTES. *MR
or maybe this one
Service Bulletin Number: 7816
Bulletin Sequence Number: 122
Date of Bulletin: 0002
NHTSA Item Number: SB612222
Make: FORD TRUCK
Model: F150
Year: 1999
Component: EQUIPMENT:ELECTRIC POWER ACCESSORIES
Summary: SOME VEHICLES MAY EXHIBIT INTERIOR LIGHTS, POWER WINDOWS AND / OR INOPERATIVE RUNNING
BOARD LIGHTS FOR A SHORT PERIOD OF TIME IN THE MORNING. *TT
[This message has been edited by dave_f (edited 09-27-2000).]
Old Sep 27, 2000 | 10:08 PM
jake565's Avatar
Thumbs up
To Dave-f, thanks for the info
Tom J.
