keyless entry/alarm
I have a 1998 supercab that has the keyless entry/alarm system installed at the factory. I have had the alarm go off occasionally without anyone around the truck. In fact it has gone off sitting in my garage or driveway unlocked which I would assume means the alrm is not activated. Has anyone had a similar experience or a solution to this problem? Thanks
JMSMBRY,
CALL YOUR LOCAL FORD DEALER AND SEE IF THE KEYLESS ENTRY BOX CAN BE REPROGRAMED WITH ANOTHER CODE. YOU MAY BE GETTING A SIGNAL FROM SOMEONE ELSE THAT MAY LIVE BYE YOU THAT ALSO HAD KEYLESS ENTRY. I HAD THAT PROBLEM WITH A GARAGE DOOR OPENER FROM A NEIGHBOR DOWN THE STREET. THE FACTORY CODES WERE THE SAME AND YOU ARE SUPPOSE TO CHANGE THEM ONCE THEY ARE INSTALLED. IT WONT HURT TO CALL AND SEE.
