Headlight Bulb Replacement
Old Jun 14, 2000 | 10:10 AM
Rich Fritz's Avatar
Question Headlight Bulb Replacement
Has anyone replaced a headlight bulb on their 1997 F150 SC? It looks like two retaining clips must be removed and then the entire headlight lens assembly pulls out from the front.
Old Jun 14, 2000 | 02:54 PM
DirtSlinger's Avatar
Lightbulb
Hi Rich,
You're on the right track. Pull up on the two black retaining brackets to release the headlight assembly. You can push on the threaded bolts going through the bracket from behind while wiggling the front of the headlight housing to work it out of the brackets alittle and it will soon become loose and come right out. I believe you only need to pull out the passenger side housing alittle to get to the bulb socket..the drivers side should be accessable without dissassembly. The bulb sockets unscrew counter clockwise about 1/4 turn and come right out. Also dont put to much pressure on the little platic retaining clips that hold the plug to bulb element because they are fragile and will break..like mine did..lol..so be careful. Its a piece of cake! Hope i could help you
Jason
DS
2000 F150 XLT SC 4x2, 5.4L auto, 3.55 LS, Med Toreador solid, Med Graphite int,pwr everything except seat, CD player...*Current Mods=Stull grill,tinted windows,keyless entry/alarm,PIAA superwhites*
*** In the Works - Rancho 4" lift,3" bodylift, BFG AT-ko 35x12.50's,16x10" American Racing Baja's,Rancho RS9000's,Hellwig swaybar,pre-runner bumper w/4 100w's,custom 3" cat-back w/40series Flowmaster,4.56 gears,Flip-chip,Black nerf's,Fosgate amp/JL subs/MB Quart seperates***
Im such an ***...
Old Jun 14, 2000 | 05:08 PM
Rich Fritz's Avatar
Thumbs up
Thanks Jason. Your advice was right on the money. I replaced both bulbs in less than five minutes. Now if only the spark plugs were this easy......
Thanks again, Rich
