Fog Lights/Without Headlights
Old Mar 13, 2000 | 06:21 PM
I95's Avatar
I95
Question Fog Lights/Without Headlights
Awhile back there was a couple of threads about using your Fog Lights without having to use your Headlights. I tried the search feature, but, was not successful. What would I look under, or can someone please repost that information.
Thanks for your help as usual. I always get great info here.
Old Mar 13, 2000 | 07:32 PM
BigBunnell's Avatar
Post
Its not that bad, its makes it easier, if you have a wiring diagram, and know a little about relays. The way it comes from the factory, the signal for the foglight relay comes from the low beam circuit. You need to change this so that it gets its signal from the parking light circuit. The foglights are switched on the ground side of the signal circuit on the relay. You will need another switch, because the factory switch can only be pulled out once the headlights are on. The added bennefit to doing this is that your foglights also stay on with the high beams. The relay for the fog lightsare in a little box next to the power distribution box under the hood. If you need more info, just holler, I just did this off of the top of my head, I did my truck like this several months ago(actually just days after I got it). I can go look at mine, and give you better info if you need.
BigBunnell
98 F150 4X4 XLT flareside V6 5sp K&N Flowmaster and some other goodies
Old Mar 24, 2000 | 06:19 AM
scamp's Avatar
Post
The wiring is not hard, check Haynes manual page 12-26. The other switch is not needed if you have a Dremmel tool and a little patience. When you remove the light switch take it to a bench and pull the guts out. You will see there is a ramp cut into the side of the housing so that when the switch is rotated to the parking light position it will pull the switch back to the fog lights off position. Using your Dremmel cut the ramp back (guesstimate) to where the ramp will allow the switch into the parking light position with it still pulled out to the fog lights on position. I left the ramp there so that when I turn the lights off it will pull the switch in and also kill the fog lights.
1997 F-250 Light Duty, Super Cab, Short Bed, 5.4L, 4x4, Gibson SuperTruck exhaust, K&N Filter, BFG AT(KO) 285/75R16, Westin Black Nerf Bars, SuperChip. West Milton (Dayton), OH
Old Mar 24, 2000 | 10:32 AM
Marv1's Avatar
Post
FYI: For you California drivers, running with foglamps and parking lamps is illegal and you might get stopped/cited ("Any motor vehicle may be equipped with not to exceed two foglamps which may be used with, but shall not be used in substitution of, headlamps." CVC 24403). Why invite trouble?
Other states may allow foglamps/parking lamps but apparently California is not as enlightened.
Old Mar 27, 2000 | 06:08 PM
redwing's Avatar
Thumbs up
I95,
I have done this very mod to my 2000 XLT.
Some where in the chips area I did post the details. I'll try to find it and re post here .
Redwing
2000, F-150, XLT, SC, Flareside, 4x4, 5.4, 3.55ls, ORP,
Tow Package,BFG Allterrain T/A KO's
Downey soft tonneau, Black Westin step bars
Airaid FIPK from the Online store
Superchip from Mike Troyer
Bright REDWINGS red
Rewired driving lights from low beam dependant
to keyed toggle switch.
My Ford history; Started at Age 15 1965 f-100, 1976 f-250,
1979 f-150, 1989 Bronco2, 1990 full size Bronco,
1995 Explorer(wifes car), 2000 f-150
Old Mar 27, 2000 | 08:58 PM
I95's Avatar
I95
Talking
Redwing,
Hope you can find it..would appreciate it.
Cannot see any reason why Ford made it that you have to kept the headlights on with the fog lights..makes no sense to me.
Old Mar 28, 2000 | 09:53 AM
Marv1's Avatar
Post
Cuz its illegal in some states!!!
'99 F150 SC, 4x2, Oxford white, flareside, 5.4, 3.55 rearend,
bodyside mouldings, Snugtop hard tonneau, K&N dropin and airbox mod.
Duraliner drop-in (gave up on the Penda Nascar). Gibson Supertruck. Ford 2-piece bra. Catch-All floor mats.
No door cracks yet at 6K!!!
Future mods: 2/4 lowering, and some Roush stuff.
Old Mar 29, 2000 | 12:43 AM
redwing's Avatar
Thumbs up
To the many that have asked how to rewire your stock driving lights away from low beam dependant, Here it is:http:https://www.f150online.com/f150board...ML/000531.html
Redwing
Bright REDWINGS red
[This message has been edited by redwing (edited 03-29-2000).]
