Fuse Keeps Blowing!
I think it's the #4 fuse in the Expedition, it keeps popping. It controls the power mirrors, entry keypad and keyless remote entry. I took the Exped. to the dealer to have the electrical looked at. They had the truck for 3 days, said they fixed the problem. While washing the truck I pulled the fuse panel off and noticed that the dealer repalced the 7.5 amp fuse with a 10 amp fuse.
I voiced my concerns to the dealer regarding the placement of a larger fuse. Told them that I didn't want to be liable for any problems that might arise due to the larger fuse. They said that they are going to talk to the tech. and inquire the reason for the 10 amp.
If the dealer says that the difference between the 7.5 and 10 is minute I will ask them to document that they installed the 10 amp.
Any suggestions?
Sorry to be so longwinded.
99 4x4 XLT supercab 5.4L Flareside, Deep Wedgewood Blue/Med. Graphite w/Captain Chairs, Pioneer DEP-4000, Tint, K&N, Bedliner, 3" Catback w/3 Chamber Flowmaster, 285/75/16 BFG A/T on American Racing Python wheels, Stull Billet Grill, Clear Corner Lenses.
'00 Expedition XLT, Silver w/Dark graphite interior, 5.4L, Stull Billet Grill and some other stuff. All in all she'll stay stock. Ok, maybe a Flowmaster 50 series soon.
Any suggestions?
I would definately be concerned. I dont mean to scare you, but the fuse is blowing for a reason (like a short of some kind). If the tech put a higher amp fuse in instead of finding out what is causing it to blow, it could overheat the wiring and cause a fire. The wiring is sized for a certain amp load,(guage) too much load starts overheating the wire, burning insulation, starting fire. I would b!tch to the service manager big time! That was not a fix that was a band-aid. I would make them find out what the real problem is. Could be as simple as a bad relay. If you decide to go with the 10 amp fuse I would definately get the SERVICE MANAGER to document it AND sign it.
that way they can't weasle out of it if there is a problem later. I'm sorry for the long winded post, it just pisses me off that call that problem solving. In my experience with 3 local dealers, they dont diagnose problems anymore. If there isnt a TSB on a particular problem then they don't know how to fix it! Sorry again, I rant.
Hope you get your problem fixed!
hobbit
99 XLT,4.6L Auto,4X4,tow pkge,Factory Nerf Bars and Mudflaps, K&N filter,BugflectorII, Amazon Green/Silver, soon to be Pace Edwards Rolltop Cover, maybe a Superchip
hobbit
I would make them document they put a higher amp fuse in there. Becuase when what ever gets damaged they will be responable for it if you don't get it documented there going to blame you for putting in a higher amp fuse also find another service department that can fix it instead of a temparay fix.
I was doing some re-wiring of the stock relay to the fog lamps today so they would burn low or high beams. And I noticed a fuse in the under the hood that was wrong amperage had a 30 amp where a 15 should be. So I put the right one in. We will see if I have problems now!!!!! I think it was the headlite #23 fuse..Lariat#1
1997 Red/Silver F150 Lariat Flareside 3 Dr. SC W/ ORP & Tow Package, Complete Lariat Package Option List ,{APPEARANCE}: AVS Carbon Fiber Headlite Covers, Tail Lite Slots & Door Sill Protectors,Owens Fg. Step Boards, Tinted Windows,Ford 2-Piece Bra,20" Chrome Exhaust Tips,A.R.E Bed Cover Lid,Pendaliner Inner Tail Gate Protector,Zie-Bart Total Paint & Under Coating W/ Sounder Deadener Protection, #1 Ford Truck Plate under glass on Front Bumper, {PERFORMANCE}: 4.6L Auto, 3.55LS, 4-Wheel ABS,Platinum 3 Spark Plugs,K&N Air Filter W/ modified stock air box, Tornado Air Man.,WMS Velocity Tube,Dual Exhaust System,Per. Fiction Carbon Mettalic Disc Brake Pads,Goodyear Wrangler A/TS Tires,55 Watt(replacement) Back-up Lites, Pilot 55 watt Back-up Lites on Hitch under truck,Foglites work W/ Brites On , {STEREO}: Stock In-Dash Cass. W/6 Disc Changer & 4 Stock Speakers, {SECURITY}: Ford Security System W/ Motion Alarm All on same Key Fob, This is LARIAT 1... IN The Great State Of Indiana..........http://hometown.aol.com/terrylariat1...page/auto.html A very Proud Member of ...www.f150online.com
The 7.5 amp fuse is sized that way to protect the wiring from damage. Since 7.5 amps at 12v is 90 watts you could get enough heat to burn something, besides why would the mirrors or keypad need more power than that? If you find the fuse blows when you switch something on you've isolated the problem--say a short in power mirror motor. I would actually use a lower rating fuse to do the testing, worst it can cost is another fuse.
'99 EB Expy 4x4, 5.4L, Ox White, Air Suspended
Stock except for: Auxiliary Battery, Re-located CD Player
