Passenger airbag switch
My passenger air turn-off switch, the led bulb that indicates that is has been turned off is burnt out which is throwing an airbag code and causing the airbag light to go on. I know this because I scanned it with the mac tools task-master at school. What led do I need to replace it?
You should have had a LFC with this issue.
Searched this forum for Radioshack bulb ( this is usually the term with the LFC ), got 2 threads with the part numbers
https://www.f150online.com/forums/el...bag-light.html
Thanks, I'm checking out radioshack now.
