2006 F150 rear sliding window
Old May 13, 2010 | 09:12 PM
forest01's Avatar
My rear sliding window does not work. I had the truck about 2 years and it quit. Took it back (under warranty) and lasted about another year then quit. Any one had the same problem? If so how did you fix it?
Old May 14, 2010 | 12:30 AM
XL1200Ltd-Keith's Avatar
http://www.ford-trucks.com/forums/86...-easy-way.html
Old May 19, 2010 | 12:08 PM
mrolgren's Avatar
In the how-to section there is also an article on creating a power sliding window from a manual sliding window.
Maybe looking at the schematics will help you diagnose the problem!
Good luck!
Old May 28, 2010 | 03:15 AM
06fx4shadow's Avatar
I actually had the same problem in my 06. i used it all the time then it just stopped. when i took it into the dealership under the warranty, they said the regulator was bad that operates the window. they changed it out and it works great ever since. its been like 2 years now since its been fixed.
Did they ever tell you what they thought was wrong, and what they "fixed" when you took it in?
