Help, dome light won't go off
Old Dec 28, 1999 | 10:12 PM
Donk21's Avatar
Lightbulb
There is only one hole. You don't need to remove the plastic cover and you don't need to remove any screws (removing the plastic cover just makes it a little easier). It is the little hole next to the door hinges which the slide connected to the door disappears into(it should be the only piece of black plastic visible it is about 3 inches long and 1 inch wide and there is a hole in the middle of it and you can see the slide go in and out of the hole as you open and shut the door)just spray it in the hole.
97 F-150 4x4 3'lift 35's exaust, bumpers, intake
Old Dec 29, 1999 | 08:20 AM
LarryS's Avatar
Post
Donk,
I did what you said and the light works fine now. I will have to try it several days before I will know for sure however. I did find the black plastic cover and removed it, sprayed brake cleaner into the opening but then I had to relubricate it to get the door to close without binding. I'll let you know if the light stops working. Thanks!
Old Dec 30, 1999 | 03:07 PM
LarryS's Avatar
Post
It worked for about 30 minutes and now it won't go off again. Guess I will have to buy another switch if only I knew how and where to install it.
Old Dec 31, 1999 | 12:45 AM
Tiger's Avatar
Post
I just recovered from a dome and bedlight that wouldn't go out at all. After a week at the dealer's shop. Nothing worked. The service writer said they "didn't have any idea what was keeping the light on". I applied some additional pressure and they finally found a short between the hot ahead of the map light switch and the dome light hot circuit. Kinda hard to find. Might be a similar problem for you. A marginal short could be opening and closing with heating of the wire. Just a thought.
99, XL, SC, SB, auto, 4.6L, 255x70R16, 3.55LS, 2wd, Med Tor, Dk Grph, Raider LoRider Tonneau,
More to come!
Old Jan 11, 2000 | 04:04 PM
mudder's Avatar
Angry
Well I have the same problem, light stays on when I get in and out, and door ajar light stays on too. I noticed it when I left my truck and locked it with the remote keyless entry. It honked twice as if the door was open, but it wasn't. This only happens every once and a while. I am just out of warranty (36,900). If it keeps gettin worse I'll take it in.
Patrick aka Mudder
Arlington Texas (DFW), member of Fordified.
Stone Cold edition F150, Black 98 Styleside S/C F150 4x4 0RP 5.4 3.55ls, Ramsey Pro 8000 hidden winch, Grizzly roll bar, Superwhite Bulbs, 2 Baja lights, 8 165 watt KC lights (if I can't be the biggest I'm gonna be the brightest, so if ya need some light gimme a call, will 14 do?), Manik grille guard, Westin step bars, Rhino Taillight guards (thanks Pony), Magnum bug shield, Sonic aluminum treadplate 36" tool box, Flowmaster dual exhaust, K/N air filter, 265/75/16 BFG AT/S, American Racing Baja wheels, Cobra CB radio, a Mobil Speed Pass on the back window, a F150 Online sticker, and a Stone Cold sticker on the front windshield . More to come for the 3:16 machine: shocks, and Airaid. If you would like to see pics, email me at mudder46@hotmail.com or see pics at me and pony's new website www.angelfire.com/ok3/ponysix8, and to hear the exhaust http://www.angelfire.com/ok3/ponysix8/images/T005.wav
Ford Trucks: "when you absolutely have to have the very best".
[This message has been edited by mudder (edited 01-11-2000).]
Old Jan 27, 2000 | 08:23 PM
Donk21's Avatar
Post
Mudder, Try spraying the brake cleaner in there like I said eariler, it has fixed my problem for going on two months now.
Old Feb 13, 2000 | 01:09 PM
elmer505's Avatar
Lightbulb
It's really simple, I had this trouble when I bought my 1997 F-150 supercab about 7 months ago. The local dealer showed me how to fix it:
Holding the door open, spray some WD40, or other lube, into the door latch. While holding the doorhandle, use a screwdriver to work the latch back and forth a few times.
This lubricates the "door adjar" switch, allowing the light to go off.
Old Feb 15, 2000 | 05:55 AM
LarryS's Avatar
Post
Elmer,
I tried what you recommended but my light still stays on. I sprayed WD40 in the latch and also into the handle area. I assume you are referring to the latch as the locking mechanism that holds the door closed. I don't really see how working it with a screwdriver helps. Maybe I don't understand what you are saying. Thanks
Old Feb 17, 2000 | 11:52 AM
LarryS's Avatar
Post
It's fixed! Elmers trick worked. It just took a couple of days for the WD 40 to start working. Thanks.
Old Feb 20, 2000 | 04:01 PM
Stephen McNally's Avatar
Smile
The switch is in the door latch. From time to time it will get dirty and stick. This will happen more often if the truck spends a lot of time on a dirt road. The Brake Cleaner will work but will remove the needed lubricant. WD-40 is the best solution.
Old Feb 26, 2000 | 06:02 PM
cableguy's Avatar
Cool
Did ya all know that some of the screws that mount the dome to the ceiling also acts as a ground and if it comes loose at all your dome light circuitry will come on "all by itself", intermittently too. Had a few at work that did that. Take the cover off and re-tighten the screws.
Old Nov 27, 2014 | 08:34 AM
flyrod's Avatar
Originally Posted by Raoul
LarryS, try the Dim Control wheel for the dash lights. If it is turned to maximum brightness the Dome, Cargo and door courtesy lights(if you have them) will stay on.
This worked for me.
Old Dec 2, 2014 | 12:36 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Fifteen years, three months, twenty-three days. A new record!!!
Old Dec 5, 2014 | 02:39 PM
2stroked's Avatar
Hey, it brought you out of hiding didn't it?
Old Dec 11, 2014 | 10:42 AM
Rockpick's Avatar
Moderator &
LOL.... Moved to electrical!
