Gauges stop working
Old May 21, 2012 | 05:20 PM
  #31
shingadia's Avatar
Most common problem : Moisture entering vehicle from leakage @windsheild
Old Aug 21, 2014 | 07:31 PM
  #32
71-73mach1's Avatar
my 07 f150 is doing this same thing with the temp gauge falls to cold and the air con stops working then when it returns it starts working again. What is the possible fix?
Old Jan 29, 2018 | 11:36 AM
  #33
Dan Russell's Avatar
Ford gages
Not to spoil the funny of chasing bad things in the fords with battery dran and gage problem its a dum battery backup on it send old cluster out to be repaired like new when back and cost about 125 bucks good luck hope this helps.
Old Feb 8, 2021 | 12:27 PM
  #34
Taylordayne's Avatar
Scully just saw an old post of yours. My Brother replaced on his Ford F 150 1997 the odometer. Gauges have quit working. Can you give us some advice?
Old Apr 1, 2021 | 06:14 PM
  #35
Can you direct me how to find the following information. What Years did Ford Motor Company use the instrument cluster that they used in the 1998 Ford F-150 4.2 with TAC.
I have sent private email to you and received no answer. I don’t expect to hear from you but thought I would try a third time. Not a very easy to use forum.
Old Apr 1, 2021 | 09:01 PM
  #36
1997 and 1998.
Scully hasn't logged in for the last 3 years.
Old Apr 1, 2021 | 10:46 PM
  #37
Guess that’s why no comment. Thank you for responding.
