ONE headlight not working
I bought a used 2001 Lariat a few weeks ago. When i bought it the headlights were super dim. he had so much crap running off the lights it burnt the connecter up. I bought new headlights last week and went to turn them on and the driver side bulb would not come on. So I removed all the lights he had on the truck replaced the pig tails on both sides and now the drivers headlight still will not come on. I tried swapping bulbs with no luck. I have been driving around on just fogs and am ready to have some dang headlights...
16 is for both high beams.
26 & 28 are for the low beams.
These are the fuses in the CJB ( aka Central Junction Box / cab fuse panel ).
If you did not get an owners manual with the truck, download one from Ford
https://www.fleet.ford.com/maintenan...ls/default.asp
Hot dang your good. Fuse 26 is popped. Im at work so ill replace and hook it all up when I get home. I looked in manual but all I seen was 26. Course that was 4 beers later so I may have over looked a line or two
