Power Window Switches
Old Mar 23, 2010 | 10:56 PM
BigDawg99's Avatar
i have a 2004 Ford F150 Fx4 4x4..i am having a problem with my Window Switches..I can control Every Window and they all work great from the Drivers Side Panel..But not one of the other switches will work..they cant roll them up or Down..Can someone tell me how i can fix this
Old Mar 23, 2010 | 11:34 PM
ELVATO's Avatar
The lock out on the driver's side wouldn't happen to be engaged would it? I take it all the other switches aren't lit up?
Old Mar 24, 2010 | 12:31 AM
BigDawg99's Avatar
nah..none of them are lit up...not really too sure on the Lock out...
Old Mar 24, 2010 | 12:37 AM
SSCULLY's Avatar
Take a look at your owners manual, it will show the bottom switch ( towards the rear of the truck ) that is side to side as the window lock.
If the other switches' LEDs are not illuminated, press the switch the other way, and check again.
Old Mar 24, 2010 | 01:02 AM
BigDawg99's Avatar
thanks sscully..
Old Apr 15, 2010 | 08:59 PM
buckslayerbw's Avatar
Big Dawg, I had the exact same problem. bought a 70 dollar switch I didn't need. Pull the rubber boot back at the drivers door. I can just about guarantee there will be a broken wire. Mine was yellow with a red stripe, 16 gauge. Look hard, I bet you find it.
Old Apr 16, 2010 | 02:56 PM
BigDawg99's Avatar
thanks man...We noticed today that when we want to use the Passenger side switch..the wife will push it to the side and roll up and down..and the switch will work..But thats the only one that will work other than my Drivers side window..I will check the wiring though..Might be an easy Fix..hoping anyways
Old Apr 24, 2010 | 03:05 AM
jeepinfordguy's Avatar
i have a problem alot like this one... mine will roll all of the windows up and down with the driver switch.. however the passager front will roll down with the switch on that door but wont go back up and the rear switchs dont do any thing at all unless you hold them while trying to roll it up or down from the driver switch.... i have no clue please help
Old Apr 24, 2010 | 10:27 AM
SSCULLY's Avatar
I would say you have a problem with the switches on the other doors.
The at-rest position on them is how the driver's side switch activates the power window motor. If this works when pressing on the switch, sounds like the switch has dirty contacts in it.
Not sure what MY F-150 you have, your profile is not completed, and you did not include any specs on your truck, so I cannot include the test for the switches.
Might want to take a look in the technical articles section for a thread on repairing the switch LEDs, there is some info on newer MY trucks in there on cleaning the switch contacts. Could be just carboned contacts, and pressing on the switch moves it to a clean section, or the contacts could be bent from using the switch like this over time.
Old Apr 26, 2010 | 01:31 PM
djb633's Avatar
Power switches
I have a 2001 F150 and my power windows work but they keep blowing fuses,
I hear a clicking sound from the relay in the fuse box when I use the drivers side window switch, would this be the switch or maybe a motor problem? I have switched relays in the box and the clicking sound keeps coming from the same relay slot so it's not a bad relay. any help would be appriciated.
Thanks Dave
Old Apr 26, 2010 | 04:03 PM
SSCULLY's Avatar
Thanks Dave
They blow fuses, how often ?
Not quite sure how they can work, but blow fuses.
Old Apr 26, 2010 | 10:18 PM
My truck is a 2006 supercrew. thanks for the info and the hint to look in the tech articals. if there is any other special tips that might help me please let me know thanks
Old Apr 26, 2010 | 11:27 PM
donpablo's Avatar
Question Hijacker
Not to hijack the thread, but...
My brother's 06 F150 needs a new master switch (4-button for windows) and I found one on E-bay for an 01-02. From the pic it looks the same. Any idea if it's compatible?
Old Apr 27, 2010 | 09:03 AM
SSCULLY's Avatar
Not the same, the 97-03 MY trucks are different switches than the 04+ MY switches.
