New window switches needed, part #'s...
Old Mar 23, 2010 | 12:00 AM
AJC629's Avatar
I've tried cleaning them with no success. I need to replace drivers side and passenger side rear.
The part # shown on the driver's side is: 5L1T-14540-ABW
Part # for the other 3 doors: 5L1T-14529-ABW
I've searched a few sites listed on the website and I can't find them. It looks as if the true part number is the middle ones.
Can anyone point me in the right direction?
Old Mar 23, 2010 | 08:27 AM
SSCULLY's Avatar
The Driver's side SuperCrew & SuperCab switch is :5L1Z-14529-AA.
Not sure what the other doors part numbers are, when you order it in the trademotion system ( any of the Ford dealers selling parts online ) the path is :
MY - Ford -F150 - Mechanical Catalog
Electrical -> Body electrical -> Door -> Interior Trim.
It lists a switch for the front right and then rear switches, so it seems the other 3 doors do not share the same switch, only the rear doors.
The part numbers you list are the manufacturing/item numbers, not the part numbers ( my repalcement has the number above on the box, and the ABW number on the switch )
Old Mar 24, 2010 | 12:22 AM
AJC629's Avatar
Thanks, SSCULLY. I found the driver's side (4 switches) for about $60. I pulled the passenger side front and rear door switch and they both have the same number on them, so I'm assuming the driver's side rear door is the same. Anyone have any idea of that part #? The one's I've seen are $20 and some are $60 each as well??? I can't imagine a single OEM switch costs the same as a group of 4, but I can't find a website that contains all of them. Do they all run through the driver's side door as a master? If so, maybe I should just replace the driver's side door and see if the rest come back to life before I purchase more?
Old Mar 24, 2010 | 12:31 AM
SSCULLY's Avatar
Try a few of the Ford dealers that sell parts online.
Tasca ( site sponsor here ) has the Driver's side switch for 43.85. MSRP is 66.43, so 60.00 is not that cheap.
As I posted above, the front right is one item, and both rears are another item, so there are 3 switches listed in the Trademotion system.
Yes, all the switches cost about the same ( within 5.00 of each other ) for the supercrew and supercab cabs.
The driver's side switch does control the other windows ( window lock ).
Like posted above, use the Ford dealers selling parts online, so you are getting the correct item. If you use the path in the Trademotion system ( listed above ), you don't need the part numbers, they are listed in that section. Save yourself the messing around looking for part numbers, and save yourself ~ 15.00 to boot.
Old Mar 24, 2010 | 06:17 PM
AJC629's Avatar
SSCULLY, you mention Tasca and Trademotion, but I'm not seeing there links to purchase?
I'll just go to Tasca for the driver's side as well as look for the other 3 singles; I think they are all the same and saw them somewhere for $18 each.
Old Mar 24, 2010 | 09:05 PM
SSCULLY's Avatar
Tasca is a site sponsor here.
http://www.tascaparts.com/partlocato...?siteid=213668
When you get to that URL, you will see the Catalog section where you enter the MY, Brand and model ( ie. 2006, Ford F-150 ).
On the left side, follow the tree for
Once you get to this section, it will list 4 switches.
Driver's side for std cab
Driver's side for SCrew & Scab
Front Right
Rear doors.
You might want to make sure the ones you found for 18.00 are correct. If the site allows returns on electrical parts, you might want to think twice about ordering from them.
Old Mar 25, 2010 | 12:27 AM
AJC629's Avatar
Thanks again. Ordered the driver's side switch from Tasca; we'll see if that solves all the problems. If not, I may order 1 or 2 of the single door switches for $18. I found about 5 sites that offer that switch at the exact same price. That versus $60, I may take my chances...
Old Apr 12, 2010 | 07:05 PM
Swashbuckler's Avatar
Front Right
Rear doors.
I know this is kind of an older thread, but thanks!
Old Apr 12, 2010 | 08:49 PM
SSCULLY's Avatar
Not that old, less than 30 days. If it helped you really does not matter if it is 3 years old, that is why it is here.
You are welcome.
