2004- Factory fog lights not working??? Help!
My factory fog lights are not working, They aren't receiving any power. I checked the fuse and it is good! I checked for power at the fuse and there was 12v. I went ahead and replaced the Relay too! Still not working.
Please Help don't know what else to do!
on
Which fuse did you check ?
There is the fuse to the fog lamp relay coil, and the fog lamp relay.
When you pull the **** for the fog lamps, does the fog lamp icon on the switch illuminate ?
If you pull the fog lamp relay, you can jumper the fog lamps to check the fig lamp fuse to the fog lamps, and the bulbs.
Jumper pins 3 & 5 in the fog lamp relay socket.
