Guys need help with my alarm and keyless key pad
Old Feb 15, 2010 | 08:48 PM
gp1200r2000's Avatar
I have a 2004 F150 SC just got a alram and auto start in it,make of alarm is called Avital 5130 awesome alram and great rang for the auto start,but I want to no if there is a way I can use my Keyless keypad with my alram and auto start thanks Guys
Old Feb 16, 2010 | 02:41 AM
GreenBuck50's Avatar
You cannot. It will set the alarm off and cannot disarm the alarm.
Old Feb 18, 2010 | 12:05 AM
snowboarder7710's Avatar
technically no there is no wire that can disarm the alarm without the remote, but im going to be doing that with my viper (same parent company of DEI)....basically im going to get an extra remote, take it apart, wire it up in the door and wrap it to make it water tight. solder two wires on the contacts where the button connects and wire that to a relay. so every time that keypad is used and it sends a signal to the keyless entry module, itll also send a signal to the relay that will activate and simulate a button press on the unlock button of the remote.
i did the same thing with the factory keyless entry remote for my 07 mustang for arming the factory security sytem with my viper....i did this because the only way to get the factory installed motion sensors to work is to use the factory remote.
