2005 f150 reverse sensing wiring schematic
Old Feb 2, 2010 | 03:46 PM
privatepilot's Avatar
Does anyone have a copy of this wiring schematic they could email me? Here is my email, donnie.isaacs@gmail.com I would greatly appreciate the help!!!
Old Feb 2, 2010 | 04:05 PM
SSCULLY's Avatar
These are from the 2006 EVTM
Old Feb 2, 2010 | 04:36 PM
Thank you! Now another question. I have power to all sensors except the Outer left (drivers side). Where would you start looking for the bad wire?
Old Feb 2, 2010 | 05:24 PM
SSCULLY's Avatar
If all the other sensors have power, next place to check is Splice S4000, which is behind the bumper, to the driver's side of the license plate indent.
Could be a problem with the wire from the splice to the sensor, or a problem with the sensor connector.
Old Feb 2, 2010 | 11:18 PM
I will check the S4000 connection tomorrow. I have checked the line above the connector and no power to it, so I should be able to get power to the line and then I will see if the connector is bad, but I doubt it is.
