2004 F150 antitheft wont let start
i have a 2004 F150 and it starts and runs perfect until the ambient temp drops to severely cold ie zero or below farenheit. warms up 10+ degrees and starts perfect. anti theft light pulsates and does not go out after 3 seconds when this problem is happening. i thought i read a thread that there is a tsb out on this? any ideas?
i think there may be a code you can correct with your keyless entry i think its like if you press the lock button on your key chain 8 times and then the unlock i think it clears the code if thats not it look for something on this site i think i saw something like this b4 i hope i helped
OK, the TechTip ( TSB ? ) that you might be talking about is with the PIK3 antenna.
The problem that the TechTip has :
The job aid for the additional loop is for the PIK3 unit, which may or may not help your problem.
Drop me an email via my profile, and I can send you the PDF.
The file name ( please include in your email ) is PIK3_Antenna_TechTip.pdf
IPATS signal strength is lower than earlier EPATS systems and may result in an
improper PIK3 read at low temperatures on some vehicles.
