anyone remove fuse box in 2004 f150 CC need help with removel
So i figured out why almost everyone of my lights dont work in my truck..almost everysingle fuse was blown when i installed my cb radio...now here is the problem while replacing the fuses i went to push the radio power one back in and the little metal clips inside the fuse box that holds the fuse fell in to the box... so NOW i have to ****ing remove the damn box and plug those clips back in does anyone know how to remove the fuse box which is under the dash on the passanger side i need help with this or i will never have radio agian
Not sure how much it could help or how close they are, but I could post the directions for an 03 Expedition after class, assuming someone doesn't post the F150 directions first, and you might be able to guide yourself from that.
From what I remember, it involves taking off the kick panel and some other of the trim pieces, unbolting it (I think 2 bolts), and disconnecting like 4 huge connectors, along with the main power wire. Was a little bit of a PITA reaching in and disconnecting some of the connectors. Not sure... hopefully someone posts the correct info.
