2004 f-140 xlt no Tail lights or dash lights
Old Jan 26, 2010 | 11:02 AM
steve_dowg2001's Avatar
i have no tail lights or dash lights on my 2004 f-150xlt but the brake lights do come on. The fog lights only come on while the high beams are on. when you turn the fog lights off the little light for the foglights on the switch blinks once.
i dunno if this is a short somewhere or is the switch bad. tryin to figure out how to remove the switch. any help would be great.
Old Jan 26, 2010 | 11:21 AM
SSCULLY's Avatar
Did you check the fuse for the parking lamps ?
Both of these have a common fuse, the parking lamp fuse. The dash lamps have another fuse after the switch, before the dimmer.
Old Jan 26, 2010 | 01:02 PM
The guy that owned the truck before me said he had trailer brakes hooked up with a box and he said the dealer said that was the probelm soo they uninstalled the trailer brakes box but that wasent it. im wondering if the wiring harness would have a short or somthing and how do i cheack that. i have cheacked all fuses everything is fine. i know when i turn the headlights on the fuse box clicks. im not really good with electrical stuff but willing to learn.
Old Jan 26, 2010 | 03:15 PM
SSCULLY's Avatar
Do the front parking lamps work ?
If not, and if the fuse is good, and you do not have power at the bulb connector, then you have it down to a bad switch.
If they do, you have an issue with the wiring.
Did you check the splice locations for the non factory trailer plug ?
Old Jan 26, 2010 | 05:30 PM
the parking lights do not work hmm i hope its the switch going out to check bulbs to see if i have power there i tired to pull the headlight switch out it will not come out lol the little clip wont go all the way down on the back im gonna kep tryin to get it thanks for the help hopfully its the switch.
Old Jan 26, 2010 | 07:23 PM
using volt DC it showed 0 power to the parking light soo does this mean the switch is def bad ??? because im going to buy one is there a way to cheack the switch?
Old Jan 28, 2010 | 11:02 PM
Also just found out 5 mins ago the whole passenger side is wet right where the wiring harness goes along the little channel in the floor. I did a search and i guess its the 3rd brake light leaking.If its not the head light switch i guess it is this leak that messed up something with the wiring harness.If there is a short from it being wet wouldent i have a blown fuse? this sucks i just got the truck and need to get it inspected and on the road
i also found out the truck came with a factory towing box for trailer brakes dunno if this helps but it was remove by the dealer he says.
Old Feb 2, 2010 | 10:49 PM
dobrienj's Avatar
I just spent the last 2 days working on my truck for the same problem. It ended up being a short in one of the rear license plate lights. I hit a pot hole with my truck and lost all the parking lights and dash lights. It blew a fuse under the hood. it was a 15 amp fuse. It was the fuse for the parking lamps. Look in your owners manual for the location. I found the short by looking at the sockets for all the lights. this one was melted.
Old Feb 2, 2010 | 10:54 PM
dobrienj's Avatar
I bought a used switch from a junk yard. this was not the problem, a new switch is well over 100 dollars. good luck
Old Feb 4, 2010 | 10:19 PM
BKT1's Avatar
I just fixed my 04 FX4 with similar problems. It was a loose junction connection under the left kick panel. The junction is bolted together and the bolt was loose, I titened it and my tail lights came back on, plus a hole lot more in my truck started to work again. Just my 2 cents.
