Need Help Finding Empty Fuse
Old Jan 25, 2010 | 12:38 PM
08stx4x4's Avatar
I'm going to be adding some lights next weekend and want to run them so that they can only be on when the trucks Ignition is in ACC/Run/Start.
I would like to run it to an unused fuse spot in the box behind the passenger kickpanel but can't figure out which one it could be.
I looked in my Owners manual and there wasn't much info there.
The truck is a 2008 F150 STX 4x4 Supercab. I haven't made any additions to the fuse box yet. The fuse only needs to be 10A since the lights are all LED and don't pull much power anyways.
Old Feb 2, 2010 | 09:28 PM
Big_Boy's Avatar
What about fuse location 39 or 41 in the manual it says that both are not used.
Old Feb 3, 2010 | 04:42 AM
code58's Avatar
Is that on an '08, BB?
Old Feb 8, 2010 | 02:22 PM
Big_Boy's Avatar
According to the website manual both of those spots are unused. Look at the following website. https://www.flmowner.com/servlet/Con...OwnerGuidePage
Old Feb 9, 2010 | 03:49 AM
code58's Avatar
If you'll notice, the reason they're not used is because they aren't even there!
Old Feb 9, 2010 | 08:48 AM
SSCULLY's Avatar
Not sure what the OP is looking for in an "open fuse".
The fuse panel does not have aux fuses in it, so any open fuse slot would require removing the fuse panel and adding the fuse legs ( could be 1 or both sides of the open fuse slot ).
If you need an aux fuse, use an Add-a-Fuse to create the new fuse slot.
Old Feb 10, 2010 | 04:49 AM
code58's Avatar
=SSCULLY;4082257]Not sure what the OP is looking for in an "open fuse".
Scully- On the '08 it doesn't even show as having those positions (39&41) in the diagram of the fuse box. They are listed in the fuse listing as "not used" but they seem to have changed the box a little from the '04-up and completely deleted the positions. They've moved what was in those slots to other positions.
By the way Scully- how's the weather in Chi-town? Or shouldn't I ask?
Old Feb 10, 2010 | 07:16 AM
SSCULLY's Avatar
Didn't know if the power side of those slots are installed. year to year Ford changes how they do things, so one side could be populated ??
Snow is not bad, the blowing and drifting is the PITA now. Makes traffic look as bad as yours
Old Feb 12, 2010 | 05:05 AM
code58's Avatar
Born and raised in Ill. and spent the last 2&1/2 yrs in Chicago so I know what you mean on both ends. That move was a long time ago though. Wife and I both have some family back there, so we're back from time to time- We try not to make it this time of year though.
