1998 Ford F150 Headlight issue
Old Dec 12, 2009 | 09:45 PM
Flacker's Avatar
1998 Ford F150 Headlight issue - High Beam/DRL okay, no Low Beam
Hi Guys,
I have an F150 that I can't get the low beams working on.
I have disassembled the MFS and cleaned all contacts. It functions without any issues. (signals, high beams flash, high beams come on, but no low beams)
I have DRL (Daytime Running Lights) and they function as expected. The high beams also function as expected. I think it may be the DRL relay as they work but the low beams never come on. I know the low beam circuit runs through a resistor for DRLs, so the circuit and fuses are good, it just never kicks into regular low beams. Even if I could take the DRL resistor out of the equation I think it would work.
Were is the DRL resistor on a 1998 F150?
Any assistance is appreciated.
Cheers,
Flacker
Old Dec 13, 2009 | 01:00 AM
masseyman's Avatar
Is it possible that both of your low beams are burned out?
Old Dec 13, 2009 | 01:38 AM
SSCULLY's Avatar
No DRL resistor or DRL relays in the 1997 & 1998 MY trucks.
The 1997 & 1998 MY have a DRL module that pulses the voltage to create the same additional resistance load as the 1999 + MY trucks have with the DRL resistor.
I would say either low beam fuses or low beam bulb ( as masseyman posted ).
The 1997 & 1998 MY, the DRL is on the high beam element on the bulb.
Check fuses #26 & #28, and if they are good, check the bulb connector for power on the low beam circuit ( L= Dark Blue w/ White stripe / R=Dark Green w/ Orange Stripe | Black is ground on the bulb connectors ).
Sorry, you have your 1998's DRL function confused with a newer MY truck.
Old Dec 13, 2009 | 07:27 PM
Flacker's Avatar
Okay thanks for the clarification. I will test for power on both sides of 26 and 28. I had the multi****ion switch out and one of the spring loaded contacts is really burnt. I would assume the MFS is downstream of the fuse box. The contact in question is definately related to high/low function.
Should I just put a new switch in?
Thanks,
Flacker
Old Dec 13, 2009 | 10:19 PM
SSCULLY's Avatar
Fuse -> main headlamp switch -> MFS -> Fuses -> headlamps
When testing 26 & 28, make sure the main headlamp switch is turned to the headlamp position, and the MFS is pulled back ( in the low beam position ), else the fuse will be dead on both sides.
Old Jan 3, 2010 | 02:31 PM
Flacker's Avatar
Thanks guys, turned out to be a bad contact on the MFS, once the switch was replaced all works as expected.
Old Oct 28, 2014 | 09:51 PM
tmonk12's Avatar
headlights
Does the 98 ford f150 have ground side switch headlights
Old Oct 29, 2014 | 08:51 AM
SSCULLY's Avatar
Are you asking if the ground side is what the switch activates to turn the headlamp on / off ?
If I read that correctly, no it is +VDC.
