cruise control
Old Nov 4, 2009 | 11:54 AM
streetglide07's Avatar
cruise control
Any ideas on why cruise control not working got power at fuse, fuse is good when i try to turn it on it wont work not even the light comes on
Old Nov 4, 2009 | 12:34 PM
SSCULLY's Avatar
Does your CHMSL work ?
Did you do any mods ( LED tail lamps ) ?
Old Nov 4, 2009 | 02:33 PM
yes i changed rear third brake light to the recon lamp and put in putco led bulbs / dont know if the chmsl works get nothing when i turn on the switch at the wheel / i have had leds bulbs in for a while i upgrade to a newer bulb dont recall if cruise worked before these bulbs would this affect the abs as well
Old Nov 4, 2009 | 02:56 PM
SSCULLY's Avatar
That is the problem.
Known problem with the LED CHMSL.
Either you need the load resistor, or go back to the factory one.
Old Nov 4, 2009 | 03:25 PM
replace just the bulbs to stock and or third brake light any ideas were to get good load resistors do i need them on both sides
Old Nov 4, 2009 | 04:24 PM
SSCULLY's Avatar
Don't recall if the CHMSL as a LED with standard bulbs did the trick, I would think so.
I have a cap installed, and it is a LED CHMSL, and I have standard bulbs in the tail lamp housings, and my CC works. Never metered it, to see if there is a load resistor by the manufacture or not.
Try replacing the Stop/Tun/Tail bulbs back to incandescent bulbs, and test the CC.
Old Nov 4, 2009 | 09:43 PM
cruise works now with stock bulbs i wonder if this confused the abs as well need to find good resisters to handle the draw of the new leds thanks for the help
