2000 Lariat Door Lock Mystery
Old Oct 27, 2009 | 09:01 AM
TimT's Avatar
Still cannot get the door lock to via remote, door switch, etc....here is what they do:
- Both locks are activly energized in the unlock postion...if you push down on the lock "tab" it pops right back out.
- If you depress the lock swith on either door both actuators start clicking repetitively-I have to pull the fuse to stop.
- I can pull the cable off the battery, wait a few, reconnect, and then the door locks will work perfectly with switch, keypad, or remote for a limitied times....hours.
**I notice a higher pitched whinning/humming specifically from the location of the 3 door lock relays behind the dash**
- I will leave the truck locked, come out later and it will be unlocked on it's own with the actuators clicking repeatadly. (Again, I have to pull the fuse)
What I have done:
- Replaced both actuators with OEM Ford units
- Replaced the RAP Module (No change in lock behavior)
-Bought one relay and moved it to each of the 3 door lock relay locations.
I am really at a loss here....I think my next step will be to replace the other two lock relays.....I don't think the humming is right?
Could it be the Gem? Any other ideas? Thanks.
Old Oct 27, 2009 | 09:18 AM
i'd check over the wiring where it passes through the door jam
