Light numbers, HELP!!!!
Old Sep 18, 2009 | 07:36 AM
poolboy1191's Avatar
Lightbulb Light numbers, HELP!!!!
Ok, well I would like to do some LED's in the cab of my truck. But i am running into some problems.
1) I can't find the bulb numbers on any of the bulbs I have gotten
2) I can't get the map light bulbs out
3) I went to take out the rear lights, and I can't get the plasic peace to come off to acess the bulb.
Can some one please help me!!!
Please explain to me what I am doing wrong.
thank you so much!!
Tanner
Old Sep 18, 2009 | 12:27 PM
JackandJanet's Avatar
I had a similar problem in my 2005. No information on the bulbs and no instructions on how to open the bulb housings. I found it took quite a bit of force, and I thought I was going to break something, but I didn't.
I can't give you much in the way of specifics, just see if something seems to move a bit relative to other parts and pry or pull on it. If it breaks, you'll at least be able to discover how it SHOULD have come apart and then you can look for a replacement in a junkyard.
And once you get the housing open, you'll be able to tell what kind of bulb it uses.
- Jack
