key fob fix?
If you are talking about the panic button, I did this 2 times, then took the remote apart, and removed that section of the switch.
It is the rubber membrane part that you remove ( after taking it apart like battery replacement ).
I scratched the contacts on the switch apart, de-soldering the switch would also work.
