High Beams
Old Sep 3, 2009 | 03:31 PM
red fire 07's Avatar
Question High Beams
So my high beams stopped working last weekend, so did basic troubleshoot, low beams work, indicator on dash works, went to owners manual for assitance and checked related fuses, so according to the owners manual relay R03 is for Hi-beams could this be the problem or is there something I'm overlooking other than going to the dealership? Thanks.
Old Sep 3, 2009 | 05:05 PM
SSCULLY's Avatar
Did you check to see if you need new bulbs ?
Did you check the high beam fuse ? ( you do not make note of which fuse(s) you checked, or how you checked them )
This is assuming you did not modifications to the truck, is this the case ?
Old Sep 3, 2009 | 05:53 PM
High Beams
SSCULLY,
I did check fuses in the fuse box that were relevant, and no to electrical mods. Could both bulbs go at the same time?
Old Sep 3, 2009 | 06:04 PM
SSCULLY's Avatar
Possible but not probable.
Do the high beams work with the FTP mode ?
Did you check the bulb connector with a meter, to make sure you have power at the bulb connector when the main headlamp switch is on, and the MFS pushed forwards ?
Old Sep 3, 2009 | 06:53 PM
OK, I'm not hip with the acronym FTP.
Old Sep 3, 2009 | 07:55 PM
SSCULLY's Avatar
Flash To Pass - owners manual has this in the controls section I do believe.
