Reverse lights wiring question
Old Aug 16, 2009 | 07:25 PM
thejake1989's Avatar
I'm installing my auxillary reverse fog lights this evening and I'm still undecided on whether or not I want to run them to a switch or wired into my current reverse lights.
I kind of like the ability to turn them on and off at convinence, but I also think I may from time to time forget to turn them on.
Any one that has done this already has positive/negative feedback
Old Aug 16, 2009 | 07:36 PM
se7en's Avatar
Wire it both ways where they come on with the reverse lights and also have a switch to turn them on when you need them..
Old Aug 16, 2009 | 07:39 PM
Any help with how that would work. Thought about that one but couldn't come up with the wiring to make it work
Old Aug 16, 2009 | 07:52 PM
se7en's Avatar
hope this helps you =)
Old Aug 16, 2009 | 08:08 PM
Simple enough. Thanks didn't think about it like that. What do you think would happen on the off chance that I had the switch on then threw it in reverse
Old Aug 16, 2009 | 08:14 PM
JackandJanet's Avatar
Don't you run the risk of leaving the reverse lights on all the time with this setup? (Including maybe with the ignition off)?
- Jack
Old Aug 16, 2009 | 08:15 PM
se7en's Avatar
nothing it would still be getting 12 volts its just sending 12 volts through a second wire its not doubling the voltage
Old Aug 16, 2009 | 08:16 PM
se7en's Avatar
allthough that may power your reverse lights also... I would put a relay in where it connects to the reverse light power .. .i gotta go somewhere i'll draw up another diagram with a relay when i get back on here tonight
Old Aug 16, 2009 | 08:20 PM
Jackandjanet. Could you please explain what your trying to say. I want to have the ability to turn them on when not in reverse or if the truck is off.
I'll probably wire them up to the switch for now since I don't have a relay now and I guess need to work out the details to have both options
Old Aug 16, 2009 | 10:05 PM
se7en's Avatar
Heres the updated diagram with relay and switches
the relays are about $5.00 at any parts store
Old Aug 16, 2009 | 10:08 PM
se7en's Avatar
- Jack
you could use lighted switches that light up when your lights are powered.
Old Aug 16, 2009 | 11:38 PM
Just got done for the night. i got the lights mounted and the wires run but i either have a bad power or ground connection right now and didnt feel like messing with it more tonight. i think for now im just gonna run it on the blue rocker switch i got.
Old Aug 17, 2009 | 12:02 AM
You can ignore what I said earlier. I sort of thought you would not want the backup lights on if the truck was turned off (totally - key out of the ignition). If you want them on whenever, then the switch in the 12v (always hot) line makes sense - although I would use a relay due to the heavy current draw. Most switches are not designed for that high an amperage value.
- Jack
Old Aug 17, 2009 | 12:10 AM
what type of relay do you suggest. i think im going to run the power to the battery tomorrow since i think its not getting enough power inside the cab.
Old Aug 17, 2009 | 08:13 AM
se7en's Avatar
They sell these relays at autoparts stores they are usually with the off road lights section. they look like a 1" cube just ask the guy at the counter tel him u heed a relay for your aux lights.
