Strange Buzzing noise????
Old Aug 13, 2009 | 12:40 PM
SSINDYKR's Avatar
Hey all, I have a quick question. I have a loud buzzing noise behind the steering whell in the dash it sounds like. It only happens when I use my blinker and seems to happen more often to the left and if I am turning the wheel at the same time??? It stops as soon as I turn the blinker off and doesnt happen every time just occasional. Any suggestions?
Old Aug 13, 2009 | 06:44 PM
JackandJanet's Avatar
I have the same thing, except it only happens to me when I signal a right turn. I haven't noticed it being effected by turning the wheel. I can usually get it to stop by returning the signal to neutral, then activating it again. Like you, it doesn't seem to happen all the time, but for me it seems to happen when I don't "firmly" move the turn signal up.
I'm reasonably sure the problem is in the Multi-Function Switch, and I'd guess that we might be hearing an electrical "arcing" in that device. I notice the turn signal is NOT working when the buzzing noise is present.
If it get's too bad, I'll investigate it. Right now it's only happening once in a while and I can live with it. Besides, it's too hot to be working on my truck right now.
- Jack
Old Aug 14, 2009 | 11:54 AM
SSCULLY's Avatar
SSINDYKR,
With your symptoms being a bit more regular, can you try changing the tilt on the steering wheel column, and see if it is the same ?
I am thinking along the lines of the harness or MFS, excluding the MFS should have no impact on which way the wheel is pointed. That would be a clock spring issue, which is airbag, horn, and controls.
Old Aug 14, 2009 | 01:54 PM
SSINDYKR's Avatar
thanks for the suggestions, I will try that tonight.
Old Aug 14, 2009 | 01:55 PM
SSINDYKR's Avatar
sounds like we got the same dog barking!! I agree, its to hot here in Indy right now. I can live with it until it gets worse.
Old Sep 20, 2009 | 09:45 PM
red69viper's Avatar
IM having the same issue with my 06 Scab. Pain in the *** annoyance. Any idea how to fix it so the signal doesnt squeal anymore? thanks
