horn help
Old Aug 9, 2009 | 02:18 PM
01f1502wd's Avatar
horn help
I got a set of these: http://www.jcwhitney.com/autoparts/S...&zmap=ZX128359
and I think that theyre supposted to go where the stock ones went. but is there a way how I can just splice the wires that go to the horn and add these in so when I "honk" both the stocks and these blow at the same time?
and I cant tell in the instructions but these just replace the stock wiring correct? the instructions don't tell too much
Last edited by SSCULLY; Aug 9, 2009 at 02:30 PM. Reason: You have got to be kidding me - that was uncalled for
Old Aug 9, 2009 | 03:00 PM
CycloneCrew's Avatar
FYI, You are going to hate those...
They sould like a 2 yr old girl with a high pitched soft toned yell
Old Aug 9, 2009 | 03:05 PM
01f1502wd's Avatar
I jerry rigged them and theyre not too bad. but im going to tap em in, ive got a black wire and a yellow w/ green stripe. im guessing the blk is neg. and the yellow is pos.?
Old Aug 9, 2009 | 04:00 PM
subcooled's Avatar
Here's a wiring list
http://www.the12volt.com/installbay/...s.asp~TID~8333
Old Aug 9, 2009 | 04:10 PM
01f1502wd's Avatar
interesting.......so... the horn trigger is what i need? or is there a horn wire?
Old Aug 9, 2009 | 04:14 PM
subcooled's Avatar
You would tap into the horn trigger wire to actuate a relay. The relay would then send power to your new horns. This would allow both factory and aftermarket horns operate at the same time.
Old Aug 9, 2009 | 04:18 PM
01f1502wd's Avatar
and those wires are under the dash. the kit didnt come with wires.. can i not tap into the 2 wires that go to the horns?
Old Aug 9, 2009 | 04:27 PM
subcooled's Avatar
It depends on how much current (AMPS) the new horns draw. It says the kit comes with a relay. Normally I don't "piggy back" any loads into existing circuits, but if the amp draw is low, it might not be an issue.
Old Aug 9, 2009 | 04:30 PM
01f1502wd's Avatar
the kit did come with a relay...but no wires. what the hell.
