Short needed to be found
Old Aug 9, 2009 | 11:52 AM
sings16_01's Avatar
I am having trouble with my 2004 F-150 5.4l. Every time I turn the ignition from Acc to run I burn out the ignition switch fuse! I was told to disconnect the harness from the ignition switch and check it with an OHM meter, not sure where to put what. I am a novice when it comes to this type of stuff. Some pointers would be VERY helpful since I've been truckless a week tomarrow!
Old Aug 9, 2009 | 12:50 PM
SSCULLY's Avatar
Have you added anything to the truck ?
Old Aug 9, 2009 | 12:57 PM
sings16_01's Avatar
NO not really! I did change my starter Fri but nothing has gotten better or worse
Old Aug 9, 2009 | 01:13 PM
SSCULLY's Avatar
What does "not really" mean.
The only electrical modification made to the truck is to swap the starter out, else it is just like it was when Ford rolled it off the line.
nothing additional, remote start, remote entry, new head unit, amps, etc ?
Old Aug 9, 2009 | 01:16 PM
sings16_01's Avatar
No after market accessories have been added to my truck. It is all the same from when I bought it from Ford
Old Aug 9, 2009 | 02:03 PM
projectSHO89's Avatar
What is the fuse #?
Old Aug 9, 2009 | 02:05 PM
sings16_01's Avatar
F 102 20a
sings16_01's Avatar
Runs the ignition switch feed
Old Aug 9, 2009 | 09:03 PM
See https://www.f150online.com/forums/el...g-04-f150.html
Old Aug 9, 2009 | 09:35 PM
sings16_01's Avatar
I see the post but did this guy ever get his truck running??? I'll check the RFI?? caps. Not sure what that is?
