SRS indicator light on
Old Aug 5, 2009 | 04:30 PM
51488LX's Avatar
In the spring my SRS indicator light on teh gauage cluster came on aad won't shut off. Both bags are intact, seat belts work fine and there has been no front impacts. Has anyone had this problem and if so what is teh fix?
Cheers
Old Aug 6, 2009 | 07:43 AM
projectSHO89's Avatar
Count the flashes at power-on to get the two digit fault code (if one is presented).
Old Aug 6, 2009 | 10:59 AM
Steve83's Avatar
Old Aug 6, 2009 | 02:31 PM
51488LX's Avatar
Thanks I'll count the flashes. AThe diagnoistc sheet is greatly apprciated.
Warren
Old Aug 6, 2009 | 02:42 PM
51488LX's Avatar
Okay counted the flashes as four pause two so I'll assume that is the two digit code for 42? which according to the diagnostic sheet is a front severity sensor. Any idea of proceed to change / replace this sensor?
Warren
Old Aug 7, 2009 | 12:45 AM
Steve83's Avatar
No, you never replace parts based SOLELY on a code (SRS, PCM, or other). There's a specific diagnositic procedure for each code, but working with airbags takes some special equipment & experience, so it's not something to learn on. Pay a pro, or just leave it alone.
