Dash lights/Tail Lights dead
Old Aug 5, 2009 | 05:55 PM
schmeg's Avatar
i have checked all fuses under dash and there is no problems there - could this be a headlamp switch problem?? How to remove/replace the switch?? I drive a 1994 F150.
Thanks in advance.
Old Aug 6, 2009 | 12:21 AM
Steve83's Avatar
Use a hook probe in the slot to remove the headlight ****. Pry out the 2 trim strips beside the column, remove the 7mm/T15 screws, and pull the cluster bezel off. Disconnect any wiring from it & set it aside. Remove the 2 phillips screws from the headlight switch bracket & pull it out of the dash. Disconnect it & check for charring around the terminals. If present, replace the connector & switch.
An old OE switch from the junkyard is better than a new Chinese one from the zone.
Old Aug 6, 2009 | 09:33 AM
schmeg's Avatar
thanks Steve83 - i'll give it a shot.
Old Aug 6, 2009 | 03:36 PM
schmeg's Avatar
btw - the gas tank switch is right beside the headlamp switch - when i am removing the trim, is there anything to watch for as far as the tank switch is concerned?? Thanks again. Steve
Old Aug 7, 2009 | 12:47 AM
Steve83's Avatar
Originally Posted by Steve83
Disconnect any wiring from it...
You can either unplug the switch, or remove it from the bezel. There are 2 phillips screws.
