Help geting wire through firewall
Old Jul 28, 2009 | 08:13 PM
FordF4220's Avatar
I just installed a new air horn under the hood but can not find a way to wire it to the switch through the firewall sugestions please thanks.
Old Jul 28, 2009 | 08:49 PM
there is a big grommet behind the drivers valve cover (kinda under the master cylinder) and it comes out just above the brake pedal.
Old Jul 28, 2009 | 09:00 PM
AntzFreshWhip's Avatar
i had the same problem with my train horn.. i ran it neatly through the door jam(not in the way of anything) and notched out the weather stripping. was easy and fast. when i do get time i will re-route it though thru the fire-wall...
Old Jul 30, 2009 | 11:52 AM
Steve83's Avatar
Don't run it thru the firewall - just tap it into the stock horn wire or relay under the hood.
