another led ?
Old Jul 8, 2009 | 07:29 PM
bigredrig's Avatar
another led ?
Ok have installed leds in all my lights except my front turns. I have put an led flasher in as well. Here is my problem I installed leds in my front turns but they only flash when the parking lights are off, but one led on each side flash with the opposite turn on. If I turn the parking lights on they stay on steady and won't flash. By the way I have an '01 f-150. Any ideas guys. Oh also I have tried bulbs from two different companies and got the same result.
Old Jul 8, 2009 | 09:42 PM
JackandJanet's Avatar
But, if you put regular bulbs back in, without changing anything else, everything works fine? If so, try putting load resistors in parallel with the LED turn signal bulbs.
I know, you should not have to do this, but, maybe it will work?
- Jack
Old Jul 8, 2009 | 11:27 PM
bigredrig's Avatar
Yeah everything works fine. What size load resistors should I use and which wire do I put them on?
Old Jul 9, 2009 | 06:06 PM
bigredrig's Avatar
Ok here is another part of what I am noticing is that when I have the leds installed and the parking lights on is that none of my turn signals work. They all stay on constant. I thought that the led flasher was supposed to correct this.
Old Jul 10, 2009 | 11:27 AM
I would have thought the flashers would take care of the problem too.
SuperBrightLEDs sells load resisters and they even have an "installation sheet". You can find them on this page: http://www.superbrightleds.com/tail-brake-turn.html
- Jack
