Dead Instrument cluster
Old Jun 23, 2009 | 04:03 AM
Banzai83's Avatar
Long story short - i cut out my electric Fan Controller, installed a switch to control the fans, and now i have several problems.
- Instrument cluster is dead - lights work, and i can use my Edge to montior the temp, speed etc. I took the cluster out, and when i reconnected the right connector, the gauges started jumping, then stopped.
-My brake/transmission interlock stopped working. When i use the override button next to the shifter, and squeeze the shifter trigger, i get a clicking in the dash near the steering wheel.
-The AC will not work.
I've checked the fuses, but cannot find anything out.
Under the dash, there is a short line comming out of the wiring harness that has 2 connectors loose. I don't recall seeing them before, but i cannot find where they go. Could this have anything to do with it?
Weird
