Door Chime Wont Stop Dinging??
Old May 31, 2009 | 12:13 PM
BPoundstone's Avatar
I just bought a 2002 F-250. The Door Ajar light is on constantly and it constantly dings at me like 4 times a minute while driving. When I open a door while I'm driving nothing happens, so I dont think its hooked up right. I dont really care if its fixed, I just need it to stop dinging is there anyway to disconnect this?
Old May 31, 2009 | 12:37 PM
SSCULLY's Avatar
When you open the door, the interior light goes off ?
Old May 31, 2009 | 01:30 PM
No openeing the door doesnt affect the lights or the door chime. Its like the door isnt connected at all.
Old May 31, 2009 | 02:06 PM
SSCULLY's Avatar
Did you try the procedure in the sticky at the top of this forum ?
Old Jun 1, 2009 | 10:03 PM
Mamay's Avatar
Just hit the seat belt button. This works on my 03 150 and my dads 01 250. Get in the truck, crank it over then hit the release button. It will stop the truck from telling you to put it on.
Wow, WOW, sorry completely missed the question. I have to go to bed.
Old Jun 3, 2009 | 08:53 AM
patco's Avatar
i hav e a similar problem with my 02 150. its like a phantom chime, a series of 5 faint dings @ 5 intervals. no door ajar light. will do this intermitantly on long trips.
Old Jun 3, 2009 | 04:50 PM
SSCULLY's Avatar
Sounds like the PAD light is out. Search on airbag light PAD you will find a few threads on the topic.
Old Jun 5, 2009 | 03:32 PM
patco's Avatar
thankyou for the air bag light sugestion.good news, you nailed it. after replacing the air bag indicator light, located in lower right corner of cluster,( and also re-soldering odo light terminal) life is good. not so good news, code 46. oh well, we'll just keep plugging away! thank you again.
Old Jun 5, 2009 | 03:53 PM
patco's Avatar
by the way, can anyone tell me where i can find air bag trouble codes? havnt any luck on search.
Old Jun 5, 2009 | 05:53 PM
SSCULLY's Avatar
This is a 2002 LFC table, should be the same as the '03. I cannot be 100% sure about this.
Seems to be the pretensioner circuit has an issue. Have you done any work under the seat as of late ?
If you search on LFC and / or pretensioner there are a few threads on it.
