Gauges.
Old May 26, 2009 | 10:14 PM
fordman18's Avatar
Gauges.
well im prettty tired of only seeing the speedometer lol
i was hoping ylal would know if i could get the whole thing like changed, im not sure if its called a cluster or a gaugeface
but i would like it to show revs and the speedometeor
and body know how much it would be?
thanks.
Old May 26, 2009 | 10:28 PM
SSCULLY's Avatar
Got some truck info to go with that question ?
Old May 27, 2009 | 08:47 PM
fordman18's Avatar
eh my bad 2004 f150 4x4 newermodel
Old May 28, 2009 | 12:51 AM
Steve83's Avatar
It's called a "fuse" and a pack of 6 costs a few bucks.
Yes, you could change out the whole cluster, but since you don't know what the problem is, that's no more likely to fix it than anything else, including a fuse.
Diagnosis first; replacement LAST.
Old May 28, 2009 | 01:48 PM
SSCULLY's Avatar
So you have the standard cluster that does not have a Tachometer and want to switch it.
The thing being is you would need to have the cluster reprogrammed for your truck. The PATS info is in the HEC, which is part of the circuit board, and that is a trip to the dealer.
So the answer is yes, but it will cost. Your dealer might use a cluster you brought in, some won't do it with used parts. You would have to ask the Ford dealer you use if they would do this.
The cluster new is pricey, so that would only add to the bill.
