Why do my tail lights and dashboard lights only go on when I brake?
on
Pull the new bulb you just installed, and see if the problem goes away.
I didn't think a new style bulb could be put in backwards, but back with the old bayonet style stop/tun/ tail bulbs, this would happen if the bulb was jammed in backwards ( pins on the side are staggered on the old bulb ).
