Additional Aux. Reverse Lights
Just picked up a 2009 supercrew 4x4. I'm interested in adding additional reverse lights. I'm planning on using two 55watt lights. I have the revese sensing system and a video camera in the tail gate. I do not want to destroy these features when installing the additional lighting. I do have a seven pin trailer connection. A few questions...
1) what would give better visibility at night fog lights or driving lights?
2) what are better...hologens or LED's?
3) what is the best way to wire the lights?
All comments will be appreciated.
Regards.....Joe
Regards.....Joe
Usually fog lamps are low and wide light patterns where driving lamps are more narrowed ( ~ 10 to 20* beam width ).
2) what are better...halogens or LED's?
Watch the Maxium "cross reference" to this, it is a dome light, and completely useless.
to wire i would run a relay fed from the battery. take the switch side off of a reverse light feed. that's the best and safest way to do it.
i would go with fog lights. when backing up at night i hate the fact that i really can't see to either side of the truck. a fog would spread the light to the sides and still project enough light behind for them to be beneficial.
Bought them online somewhere, can't recall exactly where.
I just the low cost listing from google for Truck lite 44 LED backup.
The ones in the picture above are the 54 LED version.
You can order them grommet, flange and the color of the flange.
The listing of the different versions :
http://www.truck-lite.com/webapp/wcs...3667&langId=-1
I just slapped some autozone/walmart fog lights 20$ under my truck, made a huge difference with knowing where my corners of the truck are. My back 3 windows metered in at 1% tint
https://www.f150online.com/forums/el...erse-fogs.html
I went with the White Night. I got it for my '99 and moved it to the '05. I love it. Throws a ton of light to the rear and out to the sides.
Fixed Mount Light Unit #4199. They're showing it listed for $99, I didn't pay that much 3 years ago.
I've also backed into a couple of things and busted two of the lenses but the ABS housing has taken a lickin' and kept on tickin'. Shouldn't have that problem with the reverse sensors on the '05.
I back-in everywhere to park so I can leave in a hurry if I have to. That plus having to park in in the dark at emergency scenes and then manuevering out after the call out here in the sticks makes having adequate lighting essential.
YMMV but I priced a lot of lights and kits when I bought mine, and being able to slap it onto the receiver hitch and make a couple of splices was a lot easier than spending a lot of time finding lights the right size and then trying to figure out where to mount them and then where to aim them.
BAckup Lights
I found some great lights at VIP autoparts. I have the Pilot NV-803 installed under the rear. I attached them to the square bar of the trailer hitch with some stainless band clamps. I noticed Pilot makes some new ones that look sealed. They are not too expensive and give good light. To make them work, I just put a 7 pin trailer connector on the wiring and just plug them in. If I'm pulling a trailer, I just unplug them and stow the connector under the bumper. Seems simple and easy with no wire splicing. Just another idea to look at. have fun.
Brain Teaser - Aux. Lights
Is there a way I could hook up aux. lights where it only comes on when the head lights are on and the truck is in reverse? I do not want the aux. lights on everytime the vehicle is in reverse especially during daylight hours.
Regards.....Joe
Regards.....Joe
That's the way the WhiteNight operates. It has a 3 position switch: always on, off & on in reverse.
I tried one of those, made for hooking up the trailer to be a real joy. That is one time I wanted the lights on all the time, when hooking up at night.
