Gauge lights etc
Old Apr 2, 2009 | 12:14 AM
MoshNet's Avatar
Gauge lights etc
Does anyone know where I can buy the light switch piece that has the headlight and dome light controls are controlled? The Ford dealer wants $150.00 for one, and I am pretty sure you can buy them cheaper on the 'net. Also, the clear plastic gauge cover, it has white specs on it from getting armor all on it. They wanted $40.00 for it, but I remember reading some where someone bought one for like $16.00.
I posted this before, but since I am already writing a new thread, my cruise control will not engage. Does anyone have any ideas?
Thanks guys for the help!!!
2001 F150 Lariat 5.4...
Old Apr 2, 2009 | 08:13 AM
SSCULLY's Avatar
online dealer list - Main Headlamp Switch
Mechanical Catalog
2001 Ford F150 pickup
Electrical -> Chassis electrical -> Switches -> Headlamp switch
- Choose switch type ( w or w/o Autolamp w or w/o Fog lamps )
Dealers in no particular order :
www.fastpartsnetwork.com
Fast Parts Network, LLC
652 Nautical Way
St. Augustine, FL 32080
Sales:
sales@fastpartsnetwork.com
www.southwestfordparts.com
Southwest Ford
3000 Fort Worth Highway
Weatherford, TX 76087
V: 817-596-8074
Keith Sexton Asst. Parts Manager
www.fordpartsonline.com
Bob Utter Ford
2525 Texama Parkway
Sherman, TX 75090
v:866-941-FORD
www.tascafordparts.com
F150online.com Site Sponsor
Tasca Automotive Group
1300 Pontiac Ave
Cranston, RI 02920
v: 800-915-3141
www.thinkpartsguy.com
1100 Oyster Bay Ave South
Bremerton, WA 98312
www.directfordparts.com
Silver State Ford
2121 E SAHARA AVE
LAs Vegas, NV 89104
www.tituswillfordparts.com ( previously fordparts.com )
Titus - Will Ford
3606 S. Sprague Ave.
Tacoma, Washington 98409
v: 800-637-6876
Old Apr 2, 2009 | 08:23 AM
SSCULLY's Avatar
Cruise Control
With a non functioning cruise control, have you had the recall done on it ?
Does your horn work correctly ?
Try running the Dealer Mode Test ( DTM ) to see what the CC reports.
Activating Test Mode
To enter the HEC Dealer test mode, depress and hold the instrument cluster SELECT/RESET button, turn the ignition switch to the RUN position, and then continue pressing the SELECT/RESET button (5 seconds) until tESt is displayed in the odometer. The SELECT/RESET button must be released within 3 seconds of the odometer tESt display to begin the dealer test mode.
Depress the SELECT/RESET button to advance through the following steps until dtc is displayed. Depressing the SELECT/RESET button will display any stored continuous DTCs before proceeding to the next step.
GAGE
Activates gauge sweep of all gauges, then displays present gauge values. Also carries out the checksum tests on ROM and EE. If the gauge sweep is inoperative, INSTALL a new instrument cluster.
All segments illuminated
lluminates all odometer segments. If any odometer segment is inoperative INSTALL a new instrument cluster.
bulb
lluminates all micro-controlled indicators and LEDs. Install a new indicator or LED as necessary.
r
eturns to normal operation of all micro-controlled indicators and LEDs and displays hexadecimal value for ROM level. (used when requesting assistance from the hotline). If alternating flashes for FAIL and ROM level are displayed, INSTALL a new instrument cluster.
EE
Displays the hexadecimal value for EE level (used when requesting assistance from hotline). If alternating flashes of FAIL and EE level are displayed replace instrument cluster.
dt
Displays hexadecimal coding of final manufacturing test date (used when requesting assistance from hotline).
dtc
Displays continuous DTC's in hexadecimal format. Pressing the SELECT/RESET button will display any DTCs stored before proceeding to the next step.
enG
Displays the English speed in MPH. Speedometer will indicate present speed within tolerances. Display will show 0 if input in not received. If input is invalid for one second or more, or if speed is 0.
m
Displays the metric speed data in kph. Speedometer will indicate present speed within tolerances. Display will show 0 if input in not received. If input is invalid for one second or more, or if speed is 0.
tAc
Displays the tachometer data received from the PCM via the SCP network within tolerances. Tachometer will indicate present RPM. Display will show 0 if input is no received, if input received is invalid for one second or more, or if engine RPM is 0.
FUEL
Displays the code (0-255) for the fuel sender input to the HEC. The fuel gauge will display a filtered fuel level value. This filter will keep the pointer from moving suddenly or erratically.
255 open send +/- 0
232 full stop +/- 0
215 Full mark +/- 10
178 3/4 mark +/- 8
138 1/2 mark +/- 7
93 1/4 mark +/- 5
41 E mark +/- 4
54 Low Fuel (0-59)
0-18 short (0-20 max)
OIL
Displays the code (0-250) for the oil pressure switch input to the HEC. Oil pressure gauge will indicate present oil pressure. Normal oil pressure (greater than 6psi) will display a value between 000 and 176. A low oil pressure or an inoperative engine oil pressure switch (less than 6 psi) will display a value greater than 176.
dEGC
Display of engine temperature in Degrees C input from cylinder head temperature sensor.
49 C "C" mark
60 C Normal band start
120 C Normal band end
-40 C No SCP message for 5 seconds
bAtt
Displays the code (0-255) for the battery voltage input to the HEC. Battery voltage gauge will indicate present battery voltage.
93-102 6.2-9.1 volts, low voltage
115-124 8.5-10.7 volts, Normal band start
215-225 15.8-18 volts, Norm band end
230-241 16.9-19.1 volts, high voltage
rhEo
Displays the present decimal rheostat dimming input, 0-255 (used when requesting assistance from the hotline)
rhi
not used
rhS
not used
rho
not used
Cr
Displays the current RUN/START sense input. Display will show -h for high input with the ignition switch in the START position and -L for low input with the ignition switch in the RUN position.
PA-PE7
not used
GAGE
Repeats the display cycle
Source: Helms 99 manual.
